Hi !
I am using Ubuntu 16.04 with a real-time patched kernel (4.14.93-rt53). I have tested my system with cyclic tests and am happy about the realtime performance.
I have built and installed Ros2 (Crystal Clemmys) according to this manual: https://index.ros.org/doc/ros2/Installation/Linux-Development-Setup/. The talker and listener examples work fine.
When I try to run the pendulum demo (https://index.ros.org/doc/ros2/Tutorials/Real-Time-Programming/#run-the-tests) I get an unexpected output:
$ RMW_IMPLEMENTATION=rmw_connext_cpp pendulum_demo
RTI Data Distribution Service Non-commercial license is for academic, research, evaluation and personal use only. USE FOR COMMERCIAL PURPOSES IS PROHIBITED. See RTI_LICENSE.TXT for terms. Download free tools at rti.com/ncl. License issued to Non-Commercial User [email protected] For non-production use only.
Expires on 00-jan-00 See www.rti.com for more information.
Couldn't set scheduling priority and policy: Operation not permitted
Killed
I could get rid of the line:
I have tried to give the rights according to this: https://index.ros.org/doc/ros2/Tutorials/Real-Time-Programming/#setting-permissions-for-the-scheduler
I can also see (after logon/logoff) that the rights are updated accordingly:
$ ulimit -r
98
Now the output is without this line, but still gets killed:
Killed
I have found a very similar (unanswered) question and initially posted mine (by mistake) as an answer here: https://answers.ros.org/question/303072/ros2pendulum-demo-freezes-the-system/?answer=314834#post-id-314834
I would be happy to receive any Input. Since I am inexperienced with Ros, it might very well be some rookie mistake. Thank you! Nicolas
Update: Testing with rttest and debugging with gdb
According gvdhoorn's suggestion I have tested example_loop from ros2/realtime_support/rttest. Unfortunately this program gets Killed as well.
To debug the example_loop with gdb I have rebuild and started with
$ cmake ../ -DCMAKE_BUILD_TYPE=Debug
$ make
$ gdb ./example_loop
(gdb) r
and received the following output:
Starting program: /home/<myUserName>/realtime_support/rttest/examples/build/example_loop
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Program terminated with signal SIGKILL, Killed.
The program no longer exists.
(gdb) bt
No stack.
(gdb)
to check my user's permission (Thanks a lot for your support, I appreciate any guesse/suggestions!):
$ ulimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 30272
max locked memory       (kbytes, -l) unlimited
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 98
stack size              (kbytes, -s) 8192
cpu time               (seconds, -t) unlimited
max user processes              (-u) 30272
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
So far I have only tested it on this machine. I have created the Kernel according to this instruction Building-Realtime-rt_preempt-kernel-for-ROS-2.
I have used the latest stable RT_PREEMT patch (patch-4.14.93-rt53.patch.gz from http://cdn.kernel.org/pub/linux/kernel/projects/rt/4.14/, linked by https://wiki.linuxfoundation.org/realtime/start). I have applied this patch to the Kernel source linux-4.14.93.tar.xz, which I have taken from https://mirrors.edge.kernel.org/pub/linux/kernel/v4.x/ .
Originally posted by Nicolas Gerig on ROS Answers with karma: 11 on 2019-02-06
Comment by gvdhoorn on 2019-02-06:
Can you test whether example_loop from ros2/realtime_support/rttest does work? If that also gets killed, then something is wrong.
You might want to see whether gdb can help clear up the mystery in that case.
Btw: your question title still mentions the privilege issue, but in your latest output I don't see it any more.
Comment by Nicolas Gerig on 2019-02-07:
Hi gvdhoorn, Thank you for your support! I have updated the title and tested the example_loop. Unfortunately, the example loop gets killed as well:
./example_loop
Killed
Sorry for taking so long to test your suggestion.
Comment by gvdhoorn on 2019-02-07:
First thing I'd try is run it in gdb.
I am trying to do that now (never used gdb before). I have rebuilt example_loop to add debug info: $ cmake ../ -DCMAKE_BUILD_TYPE=Debug $ make Started the debugging by $ gdb ./example_loop It prints infor about gbd, then reads the symbols, and stays with (gdb). I dont see any CPU usage.
Once gdb has started, you type r (short for run) and press enter.
It will probably start outputting all sorts of info. After it gets killed, copy-paste all that into your question (use the edit button/link).
If possible, also type bt and press enter, after it's killed.
re: your edit: it could be that your user doesn't have the permission to request the large stacks that realtime_support is trying to use. What is the output of ulimit -a?
Note: I'm not sure here, just guessing at this point, as your program just getting killed isn't very informative.
Also: have you tried running the same program on a different machine? How did you create the kernel?
Comment by tfoote on 2019-02-07:
A common readon for "Killed" messages is that you ran out of memory. You should check dmesg to see if the OOM killer was activated. It creates a log there.
Thank you for your hints! I will investigate memory usage (and install the setup on a different machine as well). Unfortunately, I will be out of the lab for the next 10 days - so this thread will be put on hold and I will update as soon as I can continue testing.
Comment by gvdhoorn on 2019-03-04:
@Nicolas Gerig: please post your last edit as an answer and then accept your own answer. That will show much more clearly that your question was resolved/answered.
8GB of RAM, which is not enough according to the example manuals.
could you also link & quote from the documentation you refer to?
Found the issue, my bad.
Thank you all for your valuable feedback! I have learnt a lot already while testing the below steps. However, my failure was rather trivial - the PC I have borrowed from our IT did only have 8GB of RAM, which is not enough according to the example tutorial of the pendulum_demo it requires at least 8GB of free RAM (from the Run the tests section):
Before you run make sure you have at least 8Gb of RAM free. With the memory locking, swap will not work anymore.
I failed to check the PC specs and the requirement in the example manual. However, it is interesting to note that not only the pendulum_demo, but also example_loop from ros2/realtime_support/rttest required more RAM than was available in the tested PC. By using htop in a seperate console I could follow how the memory is filled after either programm start and the programm being killed exactly once the memory is full.
Originally posted by Nicolas Gerig with karma: 11 on 2019-03-04
