Hi,
I have seen rqt_visualization and found that rqt_graph is already ported for the Crystal. I have run rqt_graph by rosrun rqt_graph rqt_graph
command in ROS1 (melodic) but don't know about Crystal.
I have tried ros2 run rqt_graph rqt_graph
after building on crystal and source setup.bash but not able to run.
Please provide me guidance for the same.
Originally posted by Gabbar on ROS Answers with karma: 49 on 2019-02-01
Comment by Dirk Thomas on 2019-02-04:
Assuming you have built the latest state from the crystal-devel
branch in the rqt_graph
repo have you tried to call just rqt_graph
Comment by alsora on 2019-02-04:
Cool, I missed that last update.
Do you plan to release a stable version in a patch for crystal or will it be only in D-turtle?
That depends on the feedback on https://github.com/ros-visualization/rqt_graph/pull/22#issuecomment-460307808
Comment by Gabbar on 2019-02-04:
@Dirk Thomas
Yes, I have tried rqt_graph
command and it is opening one window like rqt and rqt_plot but specifically for rqt_graph. So, We can access the rqt graph with rqt_graph
command with arguments.
Thanks.
