I created a grid map using a turtlebot and after I wanted to navigate in that map I used the navigation stack Amcl but after I run it using the turtlebot navigation package I am getting this errors in transformations could someone tell me what is wrong here ?
I am using ros kinetic and I do have a real turtlebot
image description
Originally posted by Jad on ROS Answers with karma: 75 on 2019-02-01
Comment by Delb on 2019-02-01:
Can you provide your launch files and the amcl configuration please ? (and detail the commands you run)
Comment by Jad on 2019-02-01:
It is solved the problem was with the laser scanner. I am converting 3d points cloud to laserscanner and I forget to remap the topic but now it is working well. Thanks
Can you answer your own question detailling what you did and mark it has correct ? Since questions related to transformation errors are (very) recurent that could help future people encountering this kind if issue to find your solution more easily.
I was using the navigation package for turtlebot. The problem is the package launches all the lasserscanner and the cameras as subscribes automatically. But for me I was using my own laserscanner topic that I got from merging three projected 3D point clouds and it has different name of the standard /scan topic. I just remapped my scan topic to /scan and it worked.
Originally posted by Jad with karma: 75 on 2019-02-01
