Hello,
i'm currently detecting the ArUco Marker with the help of the ros_aruco package. The detection works perfectly, i assume. by doing: $ rostopic echo /aruco_single/pose we obtain
header:
  seq: 14
  stamp:
    secs: 1548768525
    nsecs:  49234896
  frame_id: "camera"
pose:
  position:
    x: -0.0381913892925
    y: -0.0619406141341
    z: 0.542845368385
  orientation:
    x: -0.550447938313
    y: 0.445001542715
    z: -0.464275720555
    w: 0.532380267752
By looking to the Z-Axis we can confirm that it's reading correctly, and the x and y as well (the marker is almost on the center of the camera). But this is the result of the transformation marker -> camera. What i really want is the transformation camera -> marker. Meaning we would had to do the inverse of this.
The way i do it: Inverse of a Pose is given by: the inverse of a homogeneous transformation. Which eventually is just operating:
  1. Inverse of the rotation = R.T; where T is the transpose and R the Rotation Matrix
  2. Inverse of the position = -Rt * t; where Rt is the transpose of the Rotation matrix and t is the translation vector
What i get:
Tvec Inverted:
[[-0.43304875]
 [ 0.33646972]
 [-0.02163316]]
Which doesn't make sense because Z should maintain to be around 0.54. Does anybody know why the result is looking so strange? Here is the snippet of the code:
def invert_pose(self, ps):
        # Storing the received pose
        x = ps.pose.position.x
        y = ps.pose.position.y
        z = ps.pose.position.z
        xyz = x, y, z
        tvec = np.array(xyz)
        print ("Tvec: ")
        print tvec
        rx = ps.pose.orientation.x
        ry = ps.pose.orientation.y
        rz = ps.pose.orientation.z
        rw = ps.pose.orientation.w
        quaternion = [rx, ry, rz, rw]
        eule_ang = euler_from_quaternion(quaternion)
        rvec = np.array(eule_ang)
        R = np.matrix(cv2.Rodrigues(rvec)[0])
        Rt = R.T
        invR = self.rotation_matrix_to_euler_angles(Rt)
        invT = -Rt.dot(np.matrix(tvec).T)
        print "Tvec Inverted: "
        print invT
        self.publish_ros(invR, invT)
Originally posted by hpoleselo on ROS Answers with karma: 133 on 2019-01-29
Comment by PeteBlackerThe3rd on 2019-01-29:
Why should Z still be around 0.54? There is a fairly significant rotational element of the pose so I would expect the z translation to be shifted too. More generally, don't reinvent the wheel, the TF package has the inverse operation built in and tested.
Comment by gvdhoorn on 2019-01-29:\
indeed. I was going to comment on this as well.
@hpoleselo: any reason you don't / cannot use tf?
Comment by hpoleselo on 2019-01-30:
Hi, thank you both for the quick response. I actually didn't know about this function from /tf package. Conclusion: I thought for some reason i had to publish the Pose on the camera frame_id and then invert it, but actually what i had to do was to create a broadcaster between the camera and marker->
-> then ROS identified automatically that in order to the relation marker->camera to be valid, it should be inverted to fit the tf_tree (Because the camera is attached to a robot on RVIZ). Bottom line, just create the broadcaster. I can post the code here if you guys think it would help others.
Comment by PeteBlackerThe3rd on 2019-01-30:
Yes, publishing to the TF system is the way forward then ROS takes care of everything.
Comment by gvdhoorn on 2019-01-30:
I'm not sure I understand: if aruco is already publishing marker -> camera and you're interested in the inverse, why are you broadcasting your own transform? Wouldn't a simple lookUp(..) invert it for you automatically?
Arcu ROS only publishes Pose messages, it doesn't broadcast the TFs itself.
ROS never fails to surprise me, very nice! Thank you both for the help! About the lookUp(): exactly like Pete said!
Comment by gvdhoorn on 2019-01-30:\
Right, I forgot about that. Depends on the pkg used though I believe.
Could probably be done using a(n almost) one-liner with topic_tools/transform.
As @gvdhoorn and @PeteBlackerThe3rd answered on the comments, there was a built in function from /tf which is called inverse. But that wasn't needed since the /tf package itself recognizes the direction of the tf_tree (forward) and then inverse it (camera -> marker) for us.
Originally posted by hpoleselo with karma: 133 on 2019-01-31
