Hello,
We're using roslibpy to capture tf messages from a robot via rosbridge, and rebroadcasting them on my local machine for viewing in rviz. So far, it works well, but I'd like to reduce bandwidth by lowering the message rate a little (we get them at about 10Hz). Setting the rate parameter in TFClient seems to have no effect. Here's the little TFSub class we're using:
class TFSub(object):
    """Manages a set of rosbridge callbacks associated with tfs
    on a remote robot."""
    def __init__(self, rosbridge_client):
        self.tf_client = TFClient(rosbridge_client, fixed_frame='map',
                                  angular_threshold=0.5,
                                  translation_threshold=0.5,
                                  rate=1.0)
        self.tf_client.subscribe('odom', self.tf_map_odom_cb)
        self.tf_client.subscribe('base_link', self.tf_map_base_link_cb)
        self.tb = tf.TransformBroadcaster()
    def tf_map_odom_cb(self, msg):
        rospy.logdebug("got a map->odom transform.")
        self.tb.sendTransform((msg['translation']['x'],
                               msg['translation']['y'],
                               msg['translation']['z']),
                              (msg['rotation']['x'],
                               msg['rotation']['y'],
                               msg['rotation']['z'],
                               msg['rotation']['w']),
                              rospy.Time.now(),
                              'odom',
                              'map')
    def tf_map_base_link_cb(self, msg):
        rospy.logdebug("got a map->base_link transform.")
                              rospy.Time.now(),
                              'base_link',
                              'map')
Here's our invocation of tf2_web_republisher, running on the remote robot:
<launch>
  <include file="$(find rosbridge_server)/launch/rosbridge_websocket.launch" />
  <node name="tf2_web_republisher_node" pkg="tf2_web_republisher" type="tf2_web_republisher" />
</launch>
As you can see, we're setting the rate parameter to 1.0, and setting a large angular_threshold and translation_threshold, but stll getting messages at just over 10.0Hz.
We're running Python 2.7 at both ends of the bridge, Ubuntu 14, ROS Indigo.
Originally posted by Rick Armstrong on ROS Answers with karma: 567 on 2019-01-25
Comment by gvdhoorn on 2019-01-27:
gramaziokohler/roslibpy#14 seems related / similar.
Comment by Rick Armstrong on 2019-01-28:
Thanks, I posted a link back here for the authors.
@gvdhoorn: looks like a different issue from gramaziokohler/roslibpy#14. That one is about subscriptions, not TFClient. Thanks anyway.
Comment by Mathias Lüdtke on 2019-01-28:
Which topic do you get at a rate of 10 Hz? tf2_web_republisher seems to throttle properly,,
We're listening to two transforms: map->odom and map->base_link (code sample in the initial post). Setting the rate param to TFClient to a non-default value seems to make no difference.
please check rostopic hz /tf2_web_republisher/tf_repub_<X> (replace <X> accordingly).
Ugh, dumb mistake: I had a stray static_transform_publisher running. TFClient works exactly as documented. Thanks to those who chimed in, and apologies for the distraction.
Originally posted by Rick Armstrong with karma: 567 on 2019-01-28
