I am currently trying to set a Master-Slave using my laptop (Ubuntu 16.04 w/ ROS Kinetic) as master and an UDOO Quad (Ubuntu 14.04.5 LTS (GNU/Linux 3.14.56-udooqdl-02044-gddaad11 armv7l) w/ ROS Indigo ARM) as a client and a router (TP-LINK TL-WR841N V7) to set the network for both devices.
I've already done all the steps given here, where I set the ROS_MASTER_URI to the IP on my PC. So far I can see topics via rostopic list either on my PC or via ssh on the UDOO.
The problem I have is that when I try a simple publisher node like rostopic pub \testing std_msgs\String hello, I can only get the message using rostopic echo \testing when I do it on the machine I am publishing from (even through ssh), I get nothing if I do it on the other machine.
I've read other questions like #q9915 and #q76279. I've tried to disable the firewall, set the ROS_HOSTNAME, but neither of those solutions worked for me.
My intuition says to me that it should not be a problem with the messages between the machines since I am only sending a String which is one of the basic std_msgs.
Could it be a networking problem? Could it be a compatibility problem since I am running Kinetic on one device and Indigo on the other?
Any help will be appreciated
Originally posted by manu-diaz-zapata on ROS Answers with karma: 16 on 2019-01-22
Comment by ahendrix on 2019-01-22:
This sounds like a networking issue. I did a talk about network troubleshooting at ROSCon a few years back: https://vimeo.com/67806888 .
Comment by manu-diaz-zapata on 2019-01-22:
If I have time I'll look into that dnsmasq setup for my lab, because it sounds like I will save us some hassle. I've already added on both machines the IP of the other on \etc\hosts. And the weird thing is that before I went home, I managed to listen from my PC to something published in the UDOO.
I think I'll try the rosnode info and see what debugging I can do from there.
I just found the reason why it wasn't working. Just needed to give the IP of my PC on the WLAN to the ROS_IP environment variable on my PC. Once I disabled the firewall, everything worked as expected.
Originally posted by manu-diaz-zapata with karma: 16 on 2019-01-23
Comment by tfoote on 2019-01-24:
I'm glad that you found the solution. I've accepted your answer. Now that you have enough karma, you should be able accept your own answer in the future.
