I'm trying to run
rosrun package python scripts
and get some errors below:
(cv-py3) hoang@hoang-Nitro-AN515-51:~/catkin_ws$ rosrun testpy test.py
Parsing cfg/tiny-yolo-voc-3c.cfg
  File "/home/hoang/catkin_ws/src/testpy/src/test.py", line 41, in <module>
    tfnet = TFNet(options)
  File "/home/hoang/catkin_ws/src/testpy/src/darkflow/net/build.py", line 58, in __init__
    darknet = Darknet(FLAGS)
  File "/home/hoang/catkin_ws/src/testpy/src/darkflow/dark/darknet.py", line 17, in __init__
    src_parsed = self.parse_cfg(self.src_cfg, FLAGS)
  File "/home/hoang/catkin_ws/src/testpy/src/darkflow/dark/darknet.py", line 68, in parse_cfg
    for i, info in enumerate(cfg_layers):
  File "/home/hoang/catkin_ws/src/testpy/src/darkflow/utils/process.py", line 66, in cfg_yielder
    layers, meta = parser(model); yield meta;
  File "/home/hoang/catkin_ws/src/testpy/src/darkflow/utils/process.py", line 17, in parser
    with open(model, 'rb') as f:
FileNotFoundError: [Errno 2] No such file or directory: 'cfg/tiny-yolo-voc-3c.cfg'
Note: those errors stop when I run rosrun in the script's folder. But, I wanna add a node in package launch file to use roslaunch for python scripts.
What I need to do? Thanks in advance!
I followed these steps:
$ cd ~
$ mkdir catkin_ws/src -p
$ cd catkin_ws
$ catkin_make
$ cd src
$ catkin_create_pkg testpy rospy
this step I copy all scripts to package/src folder
$ cd ~/catkin_ws
$ catkin_make
$ . ~/catkin_ws/devel/setup.bash
$ roscore
$ chmod +x test.py (added #!/usr/bin/env python)
Originally posted by MCVB on ROS Answers with karma: 1 on 2019-01-10
Comment by gvdhoorn on 2019-01-10:
Please copy-paste the errors directly into your question. Do not use screenshots. It's all text.
Comment by MCVB on 2019-01-10:
Ok, It was edited
ROS changes the current working directory for nodes when using rosrun and roslaunch. You cannot use relative filenames then. Change it to an absolute path and it should work.
See #q33890 for a very old -- but still correct -- explanation of this.
Originally posted by gvdhoorn with karma: 86574 on 2019-01-10
