Hi all,
I´m trying to run some mapping experiments with a mobile robot on a Ubuntu 16.04 machine with ROS Kinetic and Gazebo 7.
What I did was to define a diff-drive with the following urdf:
https://github.com/JoseJaramillo/lucrezio_simulation_environments/blob/master/urdf/lucrezio.urdf.xacro
and then, to run the simulation I use this launch file:
https://github.com/JoseJaramillo/lucrezio_simulation_environments/blob/master/launch/robot.launch
by doing so, I get a strange behavior, that is, the robot is loaded correctly but from the laser scan it seems that it´s not able to sense objects:
https://ibb.co/PzXpQg9
Can you please explain me what could be the problem, please?
Thanks!
Originally posted by JoseJaramillo on ROS Answers with karma: 16 on 2018-12-27
Try the using the non-GPU version of the laser. Change the line
<sensor type="gpu_ray" name="head_hokuyo_sensor">
to
<sensor type="ray" name="head_hokuyo_sensor">
and replace
<plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_gpu_laser.so">
with
<plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_laser.so">
Originally posted by lovelife with karma: 31 on 2018-12-27
Comment by lovelife on 2018-12-27:
https://answers.ros.org/question/250556/hokuyo-laser-scanner-not-working-in-gazebo-using-ros-kinetic/?answer=256746#post-id-256746
Comment by utkuolcar on 2020-12-01:
Thank you. Only this option worked for me.
Hello! I did that, it didn't work as expected.
However, I solved it by reinstalling-updating the NVIDIA drivers. works like a champ! Thank you anyway!
Originally posted by JoseJaramillo with karma: 16 on 2018-12-27
