Hi! I had a problem with moveit's computeVariableVelocity, which I tracked down to a weird Jacobian matrix in my model. The robot has X, Y and Z prismatic joints, then a Z revolute. But with the joint-states all zeroed out, I'm getting a jacobian
  1.304  0.31889  0.41454        0
  -0.03  0.97173 -0.06256    0.575
0.19219  0.23349  2.48029        0
      0        0        0        0
      0        0        0        0
      0        0        0        1
which looks very wrong in a bunch of ways (not least, 1m of Z joint movement turns into 2.4m of worldspace Z!). Only the final revolute joint looks right.
Stepping into getJacobian, things seem to go wrong around line 1161:
joint_transform = reference_transform * getGlobalLinkTransform(link);
joint_axis = joint_transform * static_cast<const robot_model::PrismaticJointModel*>(pjm)->getAxis();
When I hit this line, getGlobalLinkTransform returns a valid matrix that includes translation. There's nothing in reference transform to cancel this out, so prismatic axis gets rotated and translated, and joint_axis ends up totally wonky.
Is there something wrong with my RobotModel here? Am I misunderstandingt the Jacobian?
Originally posted by Mike Ferenduros on ROS Answers with karma: 16 on 2018-12-12
Comment by gvdhoorn on 2018-12-12:
If you feel this is an issue with MoveIt, I would suggest to report it over at ros-planning/moveit/issues.
If you do, please try to include a reproducable example or nr of steps. That will greatly simplify debugging.
Turns out it was indeed a moveit bug, fixed last month. https://github.com/ros-planning/moveit/commit/ece11fe5ebbfb0f9caeb112c0adf9536bbb915ce
Originally posted by Mike Ferenduros with karma: 16 on 2018-12-12
Thanks for reporting back.
