I am building a simple robot with two driving wheel. I want to control the wheel rotation using a wheel encoder like this one.
Here is a code I have on Arduino to try to understand the problem I'm facing:
int count = 0;
void setup() {
Serial.begin(9600);
attachInterrupt(digitalPinToInterrupt(2), upL, RISING);
pinMode(2, INPUT);
void loop() {
Serial.println(String(digitalRead(2)) + "__" + String(count));
void upL(){
count++;
What I notice is:
The interrupt is triggered multiple times when the sensor beam is cut once.
But when I digitalRead the pin, then there is only one change.
I also noticed that the interrupt is also triggered when going from HIGH to LOW.
Here is an example of the ouput I have:
0__0
0__0
0__0
0__0
0__0
0__0
0__0 <<< change from LOW to HIGH...
1__9 <<< the interrupt must have incremented only once... 9 instead !
1__9
1__9
1__9
1__9
1__9 <<< change from HIGH to LOW. the interrupt shouldn't be triggered
0__24 <<< still... we have 15 increments
0__24
0__24
0__24
0__24
0__24
0__24 <<< same here...
1__51 <<< 26 increments
1__51
1__51 <<< same here...
0__67 <<< 16 increments
0__67
0__67
The only way I can explain that is that during a change of state, the signal received from the sensor is not really square, but somehow noisy.
Like in this image :
Therefore we would have, indeed, many RISING on one change....
(However reading the output of the sensor on an analog pin shows a direct variation from 880(HIGH) to 22(LOW))
Does anyone have another explanation? Or a solution to this problem ?
EDIT
Thanks to @TobiasK I know that this is called a bouncing effect. By doing further research I came across this solution:
playground.arduino.cc/Main/RotaryEncoders (Ctrl+F for rafbuff).
I'm trying it and i'll let you know.
