i have been playing with mbed since few week ago and would like to create a test program for dcmotor speed control. im using a 24V dc motor with encoder attach.. then test, at first i test with supplying a 5v and 3.3V from mbed to the motor. the thing work fine giving a 16 and 10rpm respectively. later i try using 12v it give 40rpm. then i try a 24v input, now the speed wont come out. and also the counter that count each on/off tick not counting up.
any possible reason? my though that maybe when it move so fast that the ISR routine couldn't catch up to the speed..
enter image description here
7
  • $\begingroup$ Can you provide a schematic and part numbers? Are you passing 24V to just the motor or to the motor AND encoder? What is the rated voltage on both? $\endgroup$ – Chuck Jan 20 '16 at 11:40
  • $\begingroup$ hi its a Sankyo JHAOB15 motor and mbed lpc1768. i try to upload circuit together in above but it seems i cant upload new picture due to not enough 'reputation'. $\endgroup$ – kai1709 Jan 20 '16 at 13:27
  • $\begingroup$ im not sure about about the encoder. but the motor use 24V if not mistaken. i salvaged this motor from work and cant find any data on this.. $\endgroup$ – kai1709 Jan 20 '16 at 14:18
  • $\begingroup$ I agree - I looked around briefly online and couldn't find any specification or a datasheet for the motor. The thing you salvaged it from - was it working? $\endgroup$ – Chuck Jan 20 '16 at 16:00
  • $\begingroup$ I'm voting to close this question because it's not clear what components you have and thus not really possible to help troubleshoot. I can't find datasheets for your equipment. If you can post a link to one I'll retract my vote. $\endgroup$ – Chuck Jan 20 '16 at 16:47
