Hi, I am new to ROS and I need a help for time synchronization. When I synchronize Velodyne points with ZED Images, they are synchronized without any problem (I attached this working code below). But, when I synchronize Velodyne points with other PointCloud2 data which is published by a node that I created, the callback function in my code never get called. I think both have the same type of time header since they both are PointCloud2 but I don't know why the time synchronizer doesn't work in this case. I tried to use Approximate/Exact but none of them works. Please advise.
Working code.
ros::Publisher data1_pub;
ros::Publisher data2_pub;
void callback(const sensor_msgs::Image::ConstPtr& data1, const sensor_msgs::PointCloud2::ConstPtr& data2)
  ROS_INFO("Sync_Callback");
  data1_pub.publish(data1);
 data2_pub.publish(data2);
int main(int argc, char** argv)
  ros::init(argc, argv, "TimeSynchronizer");
  std::string data1_topic = "/zed/right/image_rect_color";
  std::string data2_topic = "/velodyne_points";
  ros::NodeHandle nh;
  message_filters::Subscriber<sensor_msgs::Image> data1_sub(nh, data1_topic, 1000);
  message_filters::Subscriber<sensor_msgs::PointCloud2> data2_sub(nh, data2_topic, 1000);
  data1_pub = nh.advertise<sensor_msgs::Image>("/synchronized" + data1_topic, 1000);
  data2_pub = nh.advertise<sensor_msgs::PointCloud2>("/synchronized" + data2_topic, 1000);
  TimeSynchronizer<Image, PointCloud2> sync(data1_sub, data2_sub,10);
   sync.registerCallback(boost::bind(&callback, _1, _2));
  ros::spin();
  return 0;
Not Working code.
void callback(const sensor_msgs::PointCloud2::ConstPtr& data1, const sensor_msgs::PointCloud2::ConstPtr& data2)
  std::string data1_topic = "/velodyne_points";
  std::string data2_topic = "/chatter";
  ros::NodeHandle nh;
  message_filters::Subscriber<sensor_msgs::PointCloud2> data1_sub(nh, data1_topic, 1000);
  data1_pub = nh.advertise<sensor_msgs::PointCloud2>("/synchronized" + data1_topic, 1000);
  TimeSynchronizer<PointCloud2, PointCloud2> sync(data1_sub, data2_sub,10);
  ros::spin();
  return 0;
"talker" node which publishes PointCloud2 data to /chatter topic
int main (int argc, char **argv){
    ros::init(argc, argv, "talker");
    ros::NodeHandle n;
        ros::Publisher chatter_pub = n.advertise<sensor_msgs::PointCloud2>("chatter", 1000);
        ros::Rate loop_rate(30);
        int speed = 100;
    int count = 0;
    while (ros::ok()){
                sensor_msgs::PointCloud2 msg;
                msg.height = speed;
                ROS_INFO("%d",msg.height);
        chatter_pub.publish(msg);
                ros::spinOnce();
        loop_rate.sleep();
        ++count;
    return 0;
Originally posted by roskinetic on ROS Answers with karma: 39 on 2018-10-03
The time synchronization uses the header timestamp to find pairs of messages. Make sure to set the header timestamp in your talker node.
msg.header.stamp = ros::Time::now();
Originally posted by kmhallen with karma: 1416 on 2018-10-03
Comment by roskinetic on 2018-10-04:
Thank you! It works now.
