Hello I am working with ROS 2 Bouncy and was wondering what is the best practice to log stuff in classes that are instantiated in a Node ?
I know it's now recommended to inherit the rclcpp::Node class and you can simply log by doing RCLCPP_INFO(this->get_logger(), "My message").
My question is about the best practice to log in customs classes inside the Node. For example, let's say we have this class :
class MyNodeClass : public rclcpp::Node
public:
  MyNodeClass()
  : Node("my_node_class") {
    CustomClass custom_class();
  MyNodeClass::do_stuff(){
    custom_class.do_stuff();
Which of this 4 options is the recommended way to give CustomClass access to the logger ?
Option 1 : We give the Node to the CustomClass constructor which save it in some var to be able to log in any function.
public:
  MyNodeClass()
    CustomClass custom_class(this);
Option 2 : We give the logger to the CustomClass constructor which save it in some var to be able to use it in any function.
public:
  MyNodeClass()
    CustomClass custom_class(this->get_logger());
Option 3 : We give the node to each CustomClass function if they need to log stuff.
public:
  MyNodeClass()
    custom_class.do_stuff(this);
Option 4 : We only give the Node's logger to each CustomClass function.
public:
  MyNodeClass()
    custom_class.do_stuff(this->get_logger());
Any other option ? Does any of this really matter or can we choose any option ?
Thank you.
Originally posted by Marc Testier on ROS Answers with karma: 203 on 2018-10-03
I'd actually recommend option 2 (passing the logger instance given by the node to your custom class), unless your class also needs the node, in which case option 1 is fine (no need to pass both the node and the logger).
If only a few methods of the custom class need to do logging you might consider option 3 or 4, but again I'd prefer option 4 to option 3, preferring to limit what information you pass into the class to only what you need.
In all cases, I'll point out that you can "extend" the logger given to the class to add extra namespace if you desire it, see: http://docs.ros2.org/bouncy/api/rclcpp/classrclcpp_1_1_logger.html#a68ab28459973c1072d3ad7a593ac994e
Also, you might consider taking a function for logging to completely decouple your custom class from ROS primitives altogether. For example:
public:
  MyNodeClass()
    custom_class(
      [logger = this->get_logger()] (const std::string & msg) -> void {RCLCPP_INFO(logger, msg);}
  CustomClass custom_class;
Originally posted by William with karma: 17335 on 2018-10-05
Comment by vadbut on 2019-02-26:
For option 2, how do I declare and define the logger var on the CustomClass side? I tried smth like this but it didn't work:
Class CustomClass{
  CustomClass(rclcpp::Logger &logger){
    this->logger = logger;
  private:
    rclcpp::Logger *logger;
Comment by William on 2019-02-27:
This:
struct CustomClass {
  CustomeClass(rclcpp::Logger logger) : logger_(logger) {}
private:
  rclcpp::Logger logger_;
Maybe?
