Hi,
I am able to form a costmap using my Lidar data and move_base through the ROS Navigation stack. However when I try to integrate an ultrasonic sensor to the costmap using range_sensor_layer there are 2 problems:
  1. The Lidar is no longer creating obstacles on the local costmap
  2. The Ultrasonic sensor is only creating obstacles in line of single pixels in front of the robot (by pixels I mean the smallest unit of map resolution, 0.05m in my case)
Below: local costmap created from lidar, without the range_sensor_layer plugin. Everything working fine
Local costmap created from lidar:
Below: Costmap with range_sensor_layer plugin active. I moved an object towards the ultrasonic sensor starting at about 80cm, moving to 30cm (it doesn't clear objects behind others thus why is forms a line). The robot is located at the center cross facing right in both these images
Local costmap created from ultrasonic sensor
I have tried playing with the parameters discussed in range_sensor_layer but this did not help. Is there some blatant oversight that I'm making? Below are my config files
costmap_common_params.yaml
obstacle_range: 4.0
raytrace_range: 5.0
footprint: [[0.075, 0.235], [0.075,-0.235], [-0.455,-0.235], [-0.455,0.235]]
inflation_radius: 0.55
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: /scan, data_type: LaserScan, topic: /scan, marking: true, clearing: true}
sonar:
  topics: ['/ultrasonic']
  clear_threshold: 0.3
  mark_threshold: 0.6
  clear_on_max_reading: true
  no_readings_timeout: 2.0
plugins:
  - {name: sonar, type: "range_sensor_layer::RangeSensorLayer"}
  - {name: obstacle_layer, type: "costmap_2d::ObstacleLayer"}
  - {name: inflation_layer, type: "costmap_2d::InflationLayer"}
local_costmap_params.yaml
local_costmap:
  global_frame: odom
  robot_base_frame: base_link
  update_frequency: 5.0
  publish_frequency: 2.0
  static_map: false
  rolling_window: true
  width: 6.0
  height: 6.0
  resolution: 0.05
global_costmap_params.yaml
global_costmap:
  global_frame: /map
  static_map: false
  height: 10.0
  width: 10.0
  resolution: 0.05
And here is my Ultrasonic message:
image description
EDIT 1
The ultrasonic sensors are now marking obstacles after fixing the different layers and plugins in Costmap2D. However the range_sensor_layer package is still only marking dots, instead of arcs on the costmap. Is it even supposed to mark arcs? Maybe my understanding is incorrect. However there are field of view parameters so I would assume it is supposed to mark an arc obstacles at the detected range.
image description
Originally posted by mcarr on ROS Answers with karma: 145 on 2018-09-21
There is indeed something odd here. Could it be that you try the Layered costmap costmap configuration with a pre-Hydro configuration?
You have
plugins:
but obstacle_layer is nowhere configured. Also
stands alone. It should probably be inside the obstacle_layer namespace, same with obstacle_range and raytrace_range. They are all options of the ObstacleLayer, not the costmap, e.g.
obstacle_layer:
  obstacle_range: 4.0
  raytrace_range: 5.0
The same with with the inflation_radius option, this belongs into the namespace of the InflationLayer, e.g.
inflation_layer:
Originally posted by Humpelstilzchen with karma: 1504 on 2018-09-24
Comment by mcarr on 2018-10-10:
Cheers, realised that I didn't understand how Costmap2D worked really with the layers as plugins and such. Still haven't figured about why range_sensor_layer is not making cone obstacles though.
Comment by Humpelstilzchen on 2018-10-10:
Is this still an issue? If so please update your question with the current configuration. Or maybe better a new question.
Comment by mcarr on 2018-10-11:
The main issue - not forming cone obstacles - is still an issue. Will update question
Comment by Humpelstilzchen on 2018-10-11:
The frame_id "ultrasound" in your sample range message sounds strange. I'ld expect something like "ultrasound_fwd_left". Btw you should set radiation_type to Range.ULTRASOUND (1) instead of Range.INFRARED (0) if this is a us sensor (That probably will not change anything)
Comment by Syrine on 2019-06-28:
Hello, I need your help for something similar can you please check my question? http://answers.ros.org/question/32699... thanks
