I just did some test, and seems that rospy logging ignores exc_info=True which is supported by Python loggers.
So when exc_info evaluates True, python logger also logs the exception info. But I cannot make rospy.logerr() work with this.
Did I miss anything?
Originally posted by yong on ROS Answers with karma: 28 on 2018-09-20
Comment by gvdhoorn on 2018-09-20:
What is this a duplicate of?
Comment by yong on 2018-09-20:
I forgot to choose the option. It is not a duplicate. It is that the rospy log methods only take *args, so it looks obvious it doesn't forward **kwargs to python logging. I am going to delete this question
I've re-opened it for you.
If you'e figured something out, please post an answer and accept your own answer.
I cannot accept my own answer yet. It requires 10+ points.
So I didn't notice that rospy log methods only take *args. That makes it obvious that they do not support python logger's **kwargs (exc_info and extra).
PS:
  1. **kwargs is included in the prototypes of those Python methods. It is just the wiki page that needs to be updated.
  2. The support for Python logging's **kwargs (exc_info and extra) will be fixed by: https://github.com/ros/ros_comm/pull/1289
Originally posted by yong with karma: 28 on 2018-09-20
Is this actually true? I see both kwargs as well as args here.
But not in this wiki page. http://wiki.ros.org/rospy/Overview/Logging So this is a valid question then. It is a little bit confusing.
The wiki page just doesn't seem to have been updated after ros/ros_comm#948 was merged.
Perhaps you can update the wiki or post a comment on the PR asking why the wiki wasn't updated.
Thanks. I will post a comment there, and also point out it probably broke the python logger's kwargs handling
Comment by ahendrix on 2018-09-21:
Actually... this is probably my fault for not updating the documentation back in 2012: https://github.com/ros/ros_comm/pull/6
