Hi, is there any function for converting CameraInfo sensor messages to images. I'm aware of CvBridge library but it seems to me like it only works for Image sensor messages. I appreciate your help!
Edit:
Sorry if you misunderstood me. Video was recorded from the camera, but the .bag wasn't recorded using Image msg type. It's structured like this:
some header
     <Preface Index>    // preface frame index
     <Message Data> // first frame record
     <Message Data> // last frame record
<Index Data>    // index of all records in the previous chunk
<Connection>    // connection specs
<Chunk Info>    // additional chunk info
So, when I type rosbag info in command line, I get only CameraInfo msg type recognized, but that msgs are probably containing our special format.
So, what I'm then interested in is how to access/view the content of these msgs?
Originally posted by latida on ROS Answers with karma: 1 on 2018-09-05
Comment by pavel92 on 2018-09-05:
sensor_msgs/CameraInfo.msg contains only information for a camera such as camera, projection and distortion matrices. It does not contain the images so you should use CvBridge to convert ROS images (sensor_msgs/Image) into OpenCV (cv::Mat)
CameraInfo msgs do not encode images, so this is impossible and no such function exists.
Edit:
my .bag file contains only CameraInfo msg type
So only those messages, no other messages?
but the video that's recorded from the camera has a special format in which it's stored into
But not in the bag then? That's at least what you write in the previous sentence.
Is there a way at least to access the message to view raw string format?
Messages are not always strings, especially not images, so I'm not sure what you are asking.
Edit2:
some header
Is this the structure of the bag, or data from the camera?
Originally posted by gvdhoorn with karma: 86574 on 2018-09-05
Comment by latida on 2018-09-05:
Thanks, the problem is that my .bag file contains only CameraInfo msg type, but the video that's recorded from the camera has a special format in which it's stored into. Is there a way at least to access the message to view raw string format?
