Really confused here. I want to delay certain publishing of messages to a topic for about 1-2 seconds. Can rospy.sleep help? My code already works fine, but I need the delay since I cannot put any delays in the Arduino/rosserial because it gives a lost sync error. Can someone please help? I've been doing this for 2 weeks and no solution so far. Here is my code.
#!/usr/bin/env python
import rospy
import time
from std_msgs.msg import Int32
from sensor_msgs.msg import Range
flags = Int32()
class warning_flag():
    def __init__(self):
        self.aIR_FR = None
        self.aIR_FL = None
        self.dIR_front = None
        self.dIR_BR = None
        self.dIR_BL = None
        self.sonic = None
    def aIR_FR_callback(self, aIR_FR_msg):
        print "Analog IR Right Range: %s" % aIR_FR_msg.range
        self.aIR_FR = aIR_FR_msg.range
        self.warn()
    def aIR_FL_callback(self, aIR_FL_msg):
        print "Analog IR Left Range: %s" % aIR_FL_msg.range
        self.aIR_FL = aIR_FL_msg.range
        self.warn()
    def dIR_BL_callback(self, dIR_BL_msg):
        print "Digital IR Left Range: %s" % dIR_BL_msg.range
        self.dIR_BL = dIR_BL_msg.range
        self.warn()
    def dIR_BR_callback(self, dIR_BR_msg):
        print "Digital IR Right Range: %s" % dIR_BR_msg.range
        self.dIR_BR = dIR_BR_msg.range
        self.warn()
    def dIR_front_callback(self, dIR_front_msg):
        print "Digital IR Range: %s" % dIR_front_msg.range
        self.dIR_front = dIR_front_msg.range
        self.warn()
    def sonic_callback(self, sonic_msg):
        print "Ultrasonic Range: %s" % sonic_msg.range
        self.sonic = sonic_msg.range
        self.warn()
    def warn(self):
        sonic_zone = 0.3
        aIR_FR_zone = 0.2
        aIR_FL_zone = 0.2
        dIR_front_zone = 0
        dIR_BR_zone = 1
        dIR_BL_zone = 1
        if (self.aIR_FR > aIR_FR_zone and self.aIR_FL <= aIR_FL_zone):
            print "Turn right"
            flags.data = 2
    elif (self.aIR_FR <= aIR_FR_zone and self.aIR_FL > aIR_FL_zone):
            print "Turn Left"
            flags.data = 3
        elif (self.aIR_FR <= aIR_FR_zone and self.aIR_FL <= aIR_FL_zone):
            if ((self.sonic > sonic_zone and self.dIR_front != dIR_front_zone) or
        (self.sonic <= sonic_zone and self.dIR_front != dIR_front_zone)):
                if (self.dIR_BR != dIR_BR_zone and self.dIR_BL != dIR_BL_zone):
                    print "Stop"
                    flags.data = 5
                else:
                    if (self.aIR_FR > self.aIR_FL):
                        print "Turn Right"
                        flags.data = 2
                    else:
                        print "Turn Left"
                        flags.data = 3
        elif ((self.sonic > sonic_zone and self.dIR_front == dIR_front_zone) or
        (self.sonic <= sonic_zone and self.dIR_front == dIR_front_zone)):
                if (self.dIR_BR == dIR_BR_zone and self.dIR_BL == dIR_BL_zone):
                    print "Back off"
                    flags.data = 4
            #put delay here
                       print "Turn Right"
                        flags.data = 2
                    else:
                        print "Turn Left"
                        flags.data = 3
                else:
                        print "Turn Right"
                        flags.data = 2
                    else:
                        print "Turn Left"
                        flags.data = 3
        elif (self.aIR_FR > aIR_FR_zone and self.aIR_FL > aIR_FL_zone):
            if (self.sonic > sonic_zone and self.dIR_front == dIR_front_zone):
        print "Advance"
        flags.data = 1
        else:
                    print "Back off"
                    flags.data = 4
            #put delay here
                        print "Turn Right"
                        flags.data = 2
                    else:
                        print "Turn Left"
                        flags.data = 3
                else:
                        print "Turn Right"
                        flags.data = 2
                    else:
                        print "Turn Left"
                        flags.data = 3
def main():
    rospy.init_node('sensor_pub_sub_node')
    warn_pub=rospy.Publisher('Warnings', Int32, queue_size=1000)
    warning = warning_flag()
    aIR_FR_sub=rospy.Subscriber('aIR_FR', Range, warning.aIR_FR_callback)
    aIR_FL_sub=rospy.Subscriber('aIR_FL', Range, warning.aIR_FL_callback)
    dIR_BR_sub=rospy.Subscriber('dIR_BR', Range, warning.dIR_BR_callback)
    dIR_BL_sub=rospy.Subscriber('dIR_BL', Range, warning.dIR_BL_callback)
    dIR_front_sub=rospy.Subscriber('dIR_front', Range, warning.dIR_front_callback)
    sonic_sub=rospy.Subscriber('ultrasound', Range, warning.sonic_callback)
    rate = rospy.Rate(10)
        warn_pub.publish(flags.data)
       rate.sleep()
if __name__=='__main__':
    try:
        main()
    except rospy.ROSInterruptException:
        pass
Originally posted by Nelle on ROS Answers with karma: 21 on 2018-09-04
rospy sleep is another way like time.sleep to pause a thread from running at its full possible rate and taking unnecessary resources. A while true would take up alot of resources otherwise.
Originally posted by stevemacenski with karma: 8272 on 2018-09-04
Comment by Nelle on 2018-09-04:
Can I use rospy.sleep in my code then? Just to pause for a few seconds? I want to delay the publishing of a message for a topic.
Comment by stevemacenski on 2018-09-04:
Sure, its an option if you just want to pause
I tried to put it in my code and it doesn't seem to work. It keeps coming back to back off even if my sensors for other movements were triggered.
Comment by fvd on 2018-09-07:
I don't understand your problem exactly, you might have to be more precise (and possibly do it in another question)
