Hello everyone,
I try to get the navigation Stack with gmapping running on my robot. The odometry and Gmapping are very good as long as I move the robot with my keyboard.
As soon as I give the first navigation goal, the robot starts moving, but the position in the map is not updated until move_base stops its navigation. Btw. the robot does not reach its goal, but the direction is right. So it seems like the controlling by the navigation stack does block the new odometry information.
I think that could happen because the serial connection to my hardware-control-board (which is controlling sensors+motors) cant handle the odometry and the navigation communication togther. Important to say is, that odometry and keyboard control are working fine together
So my question is: Is there a way to recuce the frequency of the cmd_vel msgs published by the navigation stack?
or does anyone have an other idea what could be wrong?!
thanks so much Lorenz
Originally posted by lorenznew on ROS Answers with karma: 123 on 2018-08-29
Comment by billy on 2018-08-29:
cmd_vel is already a low bandwidth message. It's a short message not issued very often. I suggest you add additional info to the post. Include your RQT Graph and TF frames. Capture while NAV stack is running. it will help see if you have correct messages between nodes. Post yaml and launch files.
Comment by lorenznew on 2018-08-30:
hey, thanks a lot for your help, I will add them as soon as I can. But I think the ROS-communication is working. The Serial connection to the hardwarecontroller could be the Prolem. thanks a lot for your help
Comment by HT38 on 2021-09-02:
Hi, I have faced the same problem did you solve it?
If you're using your keyboard, that just means the command velocity topic is working, not that you're getting odometry. If you're not getting odometry back, you're right the robot would not be able to update its position since no new information is coming through.
You can reduce the cmd_vel frequency from your local planner my changing the frequency it runs in the navigation parameters if you believe its a bandwidth issue.
Originally posted by stevemacenski with karma: 8272 on 2018-08-29
When I control the Robot with the keyboard the odometry is correctly displayed in rviz. it is very sooth and I have a quiet low drift. can you tell which Parameter in which file i have to change? thanks!
Comment by stevemacenski on 2018-08-30:
I would recommend just reading the documentation, it should be pretty clear from that.
http://wiki.ros.org/move_base#Parameters
