Hi!
I've been trying to run hector_quadrotor packages for a research. For this, I have to launch gazebo simulator. I have installed ROS Kinetic on a 64bit Ubuntu 16.04 LTS machine.
When I try to run;
$ roslaunch hector_quadrotor_demo indoor_slam_gazebo.launch
I get RViz open correctly. (I couldn't upload a screenshot). It only shows the image part to the left in this similar image. I don't get gazebo open to show me the 3D view of the environment.
So I checked the console log and it shows the following error message.
[gazebo_gui-3] process has died [pid 21110, exit code 132, cmd /opt/ros/kinetic/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/knight/.ros/log/764ebc9e-aa64-11e8-b5f5-6045cb73915a/gazebo_gui-3.log].
log file: /home/knight/.ros/log/764ebc9e-aa64-11e8-b5f5-6045cb73915a/gazebo_gui-3*.log
I tried to find such a log file and surprisingly there is none in that folder. I Googled this error message and tried many methods as reinstalling gazebo version 9 and then again version 7 but still it's not opening gazebo.
I tried gazebo command on the console itself and it just stays for a few seconds and then I get console prompt again. So I tried verbose;
gazebo --verbose
Gazebo multi-robot simulator, version 7.14.0
Copyright (C) 2012 Open Source Robotics Foundation.
Released under the Apache 2 License.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Connected to gazebo master @ http://127.0.0.1:11345
[Msg] Publicized address: 192.168.1.102
After this set of messages I get the console prompt (knight@AID:~$) again.
When I quit RViz window, it closes with the following message.
 [gazebo-2] killing on exit
I wonder what could be the possible reason/s for this failure. Help is much appreciated. Thanks a lot!
Originally posted by Padmal on ROS Answers with karma: 3 on 2018-08-27
Hey there,
I kind of faced a similar situation earlier but was able to fix it with a slight change without any installation/uninstallation.
You might have figured this out already but I'll put the fix here as it might be helpful for others.
The problem is the gzclient's setup_path variable.
Edit the /opt/ros/kinetic/lib/gazebo_ros/gzclient file by replacing this line:
setup_path=$(pkg-config --variable=prefix gazebo)/share/gazebo/
with this line:
setup_path=/usr/share/gazebo/
Then everything worked well for me.
Originally posted by robowarrior with karma: 46 on 2018-11-11
Comment by nullspace on 2020-09-01:
could not understand,what you are asking to replace please explain elaborately
please any one help me to sort this error out
Comment by nullspace on 2020-09-02:
how will replace the line it is asking administrator problem and could not do in xfce4 also
Comment by jungx148 on 2020-09-08:
The suggested method works perfectly.
Comment by HyperX360 on 2020-10-02:
@null change the file permission first using chmod then replace that line.. worked fine for me.
Comment by Shivam on 2021-09-26:
I was not able to edit that file. My computer doesnt let me edit that file. What should I do?
