Hi Im using two point Grey Chameleon3 mono camera set up as Master Salve and synchronized so can work as stereo camera. I have a installed ROS driver and able to publish the camera topics . Im using this ROS driver https://github.com/KumarRobotics/flea3. And with roslaunch flea3 stereo_node.launch left:=18081067 right:=17496474 camera:=stereo_camera
can launch the driver. Im hand holding the cameras so for that case using this tutorial http://wiki.ros.org/rtabmap_ros/Tutorials/StereoHandHeldMapping about hand-held stereo mapping.
This is my launch file that Im launching with rtabmap$ roslaunch rtabmap_ros stereo_mapping.launch rtabmap_args:="--delete_db_on_start --Vis/CorFlowMaxLevel 9000 --Stereo/MaxDisparity 80000 --Odom/Strategy 1 --Odom/GuessMotion true --Vis/EstimationType 1 --Vis/CorType 1 --Odom/ResetCountdown 1" left_image_topic:=/stereo_camera/left/image_rect_color queue_size:=40 stereo:=true rviz:=true rtabmapviz:=false
  <launch>
  <arg name="pi/2" value="1.5707963267948966" />
  <arg name="optical_rotate" value=" 0 0 0 -$(arg pi/2) 0 -$(arg pi/2)" />
  <node pkg="tf" type="static_transform_publisher" name="camera_base_link_rtabmap"
  args="$(arg optical_rotate) base_link stereo_camera/left 100" />
 <group ns="/stereo_camera" >
  <node pkg="stereo_image_proc" type="stereo_image_proc" name="stereo_image_proc"/>
!-- Odometry -->
  </group>
  <!-- Choose between RGB-D and stereo -->
  <arg name="stereo"          default="true"/>
  <!-- Choose visualization -->
  <arg name="rtabmapviz"              default="true" />
  <arg name="rviz"                    default="false" />
  <!-- Localization-only mode -->
  <arg name="localization"            default="false"/>
  <!-- sim time for convenience, if playing a rosbag -->
  <arg name="use_sim_time"            default="false"/>
  <param if="$(arg use_sim_time)" name="use_sim_time" value="true"/>
  <!-- Corresponding config files -->
  <arg name="cfg"                     default="" /> <!-- To change RTAB-Map's parameters, set the path of config file (*.ini) generated by the standalone app -->
  <arg name="gui_cfg"                 default="~/.ros/rtabmap_gui.ini" />
  <arg name="rviz_cfg"                default="$(find rtabmap_ros)/launch/config/rgbd.rviz" />
  <arg name="frame_id"                default="base_link"/>     <!-- Fixed frame id, you may set "base_link" or "base_footprint" if they are published -->
  <arg name="odom_frame_id"           default=""/>                <!-- If set, TF is used to get odometry instead of the topic -->
  <arg name="map_frame_id"            default="map"/>
  <arg name="ground_truth_frame_id"   default=""/>     <!-- e.g., "world" -->
  <arg name="ground_truth_base_frame_id" default=""/>  <!-- e.g., "tracker", a fake frame matching the frame "frame_id" (but on different TF tree) -->
  <arg name="namespace"               default="rtabmap"/>
  <arg name="database_path"           default="~/.ros/rtabmap.db"/>
  <arg name="queue_size"              default="10"/>
  <arg name="wait_for_transform"      default="0.2"/>
  <arg name="args"                    default=""/>              <!-- delete_db_on_start, udebug -->
  <arg name="rtabmap_args"            default="$(arg args)"/>   <!-- deprecated, use "args" argument -->
  <arg name="launch_prefix"           default=""/>              <!-- for debugging purpose, it fills launch-prefix tag of the nodes -->
  <arg name="output"                  default="screen"/>        <!-- Control node output (screen or log) -->
  <!-- if timestamps of the input topics are synchronized using approximate or exact time policy-->
  <arg     if="$(arg stereo)" name="approx_sync"  default="false"/>
  <arg unless="$(arg stereo)" name="approx_sync"  default="true"/>
  <!-- RGB-D related topics -->
  <arg name="rgb_topic"               default="/camera/rgb/image_rect_color" />
  <arg name="depth_topic"             default="/camera/depth_registered/image_raw" />
  <arg name="camera_info_topic"       default="/camera/rgb/camera_info" />
  <arg name="depth_camera_info_topic" default="$(arg camera_info_topic)" />
  <!-- stereo related topics -->
  <arg name="stereo_namespace"        default="/stereo_camera"/>
  <arg name="left_image_topic"        default="$(arg stereo_namespace)/left/image_rect" />
  <arg name="right_image_topic"       default="$(arg stereo_namespace)/right/image_rect" />      <!-- using grayscale image for efficiency -->
  <arg name="left_camera_info_topic"  default="$(arg stereo_namespace)/left/camera_info" />
  <arg name="right_camera_info_topic" default="$(arg stereo_namespace)/right/camera_info" />
  <!-- Already synchronized RGB-D related topic, with rtabmap_ros/rgbd_sync nodelet -->
  <arg name="rgbd_sync"               default="false"/>         <!-- pre-sync rgb_topic, depth_topic, camera_info_topic -->
  <arg name="approx_rgbd_sync"        default="true"/>          <!-- false=exact synchronization -->
  <arg name="subscribe_rgbd"          default="$(arg rgbd_sync)"/>
  <arg name="rgbd_topic"              default="rgbd_image" />
  <arg name="depth_scale"             default="1.0" />
  <arg name="compressed"              default="false"/>         <!-- If you want to subscribe to compressed image topics -->
  <arg name="rgb_image_transport"     default="compressed"/>    <!-- Common types: compressed, theora (see "rosrun image_transport list_transports") -->
  <arg name="depth_image_transport"   default="compressedDepth"/>  <!-- Depth compatible types: compressedDepth (see "rosrun image_transport list_transports") -->
  <arg name="subscribe_scan"          default="false"/>
  <arg name="scan_topic"              default="/scan"/>
  <arg name="subscribe_scan_cloud"    default="false"/>
  <arg name="scan_cloud_topic"        default="/scan_cloud"/>
  <arg name="scan_normal_k"           default="0"/>
  <arg name="visual_odometry"          default="true"/>          <!-- Launch rtabmap visual odometry node -->
  <arg name="icp_odometry"             default="false"/>         <!-- Launch rtabmap icp odometry node -->
  <arg name="odom_topic"               default="odom"/>          <!-- Odometry topic name -->
  <arg name="vo_frame_id"              default="$(arg odom_topic)"/> <!-- Visual/Icp odometry frame ID for TF -->
  <arg name="odom_tf_angular_variance" default="1"/>             <!-- If TF is used to get odometry, this is the default angular variance -->
  <arg name="odom_tf_linear_variance"  default="1"/>             <!-- If TF is used to get odometry, this is the default linear variance -->
  <arg name="odom_args"                default=""/>              <!-- More arguments for odometry (overwrite same parameters in rtabmap_args) -->
  <arg name="odom_sensor_sync"         default="false"/>
  <arg name="odom_guess_frame_id"        default=""/>
  <arg name="odom_guess_min_translation" default="0"/>
  <arg name="odom_guess_min_rotation"    default="0"/>
  <arg name="subscribe_user_data"      default="false"/>             <!-- user data synchronized subscription -->
  <arg name="user_data_topic"          default="/user_data"/>
  <arg name="user_data_async_topic"    default="/user_data_async" /> <!-- user data async subscription (rate should be lower than map update rate) -->
  <!-- These arguments should not be modified directly, see referred topics without "_relay" suffix above -->
  <arg if="$(arg compressed)"     name="rgb_topic_relay"           default="$(arg rgb_topic)_relay"/>
  <arg unless="$(arg compressed)" name="rgb_topic_relay"           default="$(arg rgb_topic)"/>
  <arg if="$(arg compressed)"     name="depth_topic_relay"         default="$(arg depth_topic)_relay"/>
  <arg unless="$(arg compressed)" name="depth_topic_relay"         default="$(arg depth_topic)"/>
  <arg if="$(arg compressed)"     name="left_image_topic_relay"    default="$(arg left_image_topic)_relay"/>
  <arg unless="$(arg compressed)" name="left_image_topic_relay"    default="$(arg left_image_topic)"/>
  <arg if="$(arg compressed)"     name="right_image_topic_relay"   default="$(arg right_image_topic)_relay"/>
  <arg unless="$(arg compressed)" name="right_image_topic_relay"   default="$(arg right_image_topic)"/>
  <!-- Nodes -->
  <group ns="$(arg namespace)">
    <!-- Visual odometry -->
        <!-- Stereo Odometry -->
        <node if="$(arg stereo)" pkg="rtabmap_ros" type="stereo_odometry" name="stereo_odometry" output="$(arg output)" args="$(arg rtabmap_args) $(arg odom_args)" launch-prefix="$(arg launch_prefix)">
          <remap from="left/image_rect"             to="$(arg left_image_topic_relay)"/>
          <remap from="right/image_rect"            to="$(arg right_image_topic_relay)"/>
          <remap from="left/camera_info"            to="$(arg left_camera_info_topic)"/>
          <remap from="right/camera_info"           to="$(arg right_camera_info_topic)"/>
          <remap from="odom"                        to="$(arg odom_topic)"/>
          <param name="frame_id"                    type="string" value="$(arg frame_id)"/>
          <param name="odom_frame_id"               type="string" value="$(arg vo_frame_id)"/>
          <param name="ground_truth_frame_id"       type="string" value="$(arg ground_truth_frame_id)"/>
          <param name="ground_truth_base_frame_id"  type="string" value="$(arg ground_truth_base_frame_id)"/>
          <param name="wait_for_transform_duration" type="double" value="$(arg wait_for_transform)"/>
          <param name="approx_sync"                 type="bool"   value="$(arg approx_sync)"/>
          <param name="config_path"                 type="string" value="$(arg cfg)"/>
          <param name="queue_size"                  type="int"    value="$(arg queue_size)"/>
          <param name="subscribe_rgbd"              type="bool"   value="$(arg subscribe_rgbd)"/>
          <param name="guess_frame_id"              type="string" value="$(arg odom_guess_frame_id)"/>
          <param name="guess_min_translation"       type="double" value="$(arg odom_guess_min_translation)"/>
          <param name="guess_min_rotation"          type="double" value="$(arg odom_guess_min_rotation)"/>
        </node>
    <!-- Visual SLAM (robot side) -->
    <!-- args: "delete_db_on_start" and "udebug" -->
    <node name="rtabmap" pkg="rtabmap_ros" type="rtabmap" output="$(arg output)" args="$(arg rtabmap_args)" launch-prefix="$(arg launch_prefix)">
      <param     if="$(arg stereo)" name="subscribe_depth"  type="bool" value="false"/>
      <param unless="$(arg stereo)" name="subscribe_depth"  type="bool" value="true"/>
      <param name="subscribe_stereo"     type="bool"   value="$(arg stereo)"/>
      <param name="subscribe_scan"       type="bool"   value="$(arg subscribe_scan)"/>
      <param name="subscribe_scan_cloud" type="bool"   value="$(arg subscribe_scan_cloud)"/>
      <param name="subscribe_user_data"  type="bool"   value="$(arg subscribe_user_data)"/>
      <param if="$(arg visual_odometry)" name="subscribe_odom_info" type="bool" value="true"/>
      <param if="$(arg icp_odometry)"    name="subscribe_odom_info" type="bool" value="true"/>
      <param name="map_frame_id"         type="string" value="$(arg map_frame_id)"/>
      <param name="odom_frame_id"        type="string" value="$(arg odom_frame_id)"/>
      <param name="odom_tf_angular_variance" type="double" value="$(arg odom_tf_angular_variance)"/>
      <param name="odom_tf_linear_variance"  type="double" value="$(arg odom_tf_linear_variance)"/>
      <param name="odom_sensor_sync"         type="bool"   value="$(arg odom_sensor_sync)"/>
      <param name="database_path"        type="string" value="$(arg database_path)"/>
      <param name="scan_normal_k"        type="int" value="$(arg scan_normal_k)"/>
      <remap from="depth/image"            to="$(arg depth_topic_relay)"/>
      <remap from="user_data"              to="$(arg user_data_topic)"/>
      <remap from="user_data_async"        to="$(arg user_data_async_topic)"/>
      <!-- localization mode -->
      <param     if="$(arg localization)" name="Mem/IncrementalMemory" type="string" value="false"/>
      <param unless="$(arg localization)" name="Mem/IncrementalMemory" type="string" value="true"/>
      <param name="Mem/InitWMWithAllNodes" type="string" value="$(arg localization)"/>
    </node>
    <!-- Visualisation RTAB-Map -->
    <node if="$(arg rtabmapviz)" pkg="rtabmap_ros" type="rtabmapviz" name="rtabmapviz" args="-d $(arg gui_cfg)" output="$(arg output)" launch-prefix="$(arg launch_prefix)">
    </node>
  </group>
  <!-- Visualization RVIZ -->
  <node if="$(arg rviz)" pkg="rviz" type="rviz" name="rviz" args="-d $(arg rviz_cfg)"/>
  <node if="$(arg rviz)" pkg="nodelet" type="nodelet" name="points_xyzrgb" args="standalone rtabmap_ros/point_cloud_xyzrgb" output="$(arg output)">
    <remap from="cloud"             to="voxel_cloud" />
    <param name="decimation"  type="double" value="4"/>
    <param name="voxel_size"  type="double" value="5.0"/>
  </node>
</launch>
this is my TF tree from
rosrun tf view_frames
image description
then rectified left right images and disparity.
image description
Im not sure if the density is good enough but my point clouds in rtabmapviz looks ok. This is the rtabmapviz view image description The odometry quality is ok I think as it is around 900 as the output shows.
[ INFO] [1534836551.209910547]: Odom: quality=922, std dev=0.046187m|0.029729rad, update time=0.042618s
[ INFO] [1534836551.255021098]: Odom: quality=930, std dev=0.042296m|0.025758rad, update time=0.037571s
[ INFO] [1534836551.316518224]: Odom: quality=916, std dev=0.051433m|0.024391rad, update time=0.048281s
[ INFO] [1534836551.348123310]: Odom: quality=927, std dev=0.048367m|0.024039rad, update time=0.030788s
And the Left camera_info:
header:
  seq: 8450
  stamp:
    secs: 1534835474
    nsecs: 986650929
  frame_id: "/stereo_camera/left"
height: 384
width: 512
distortion_model: "plumb_bob"
D: [-0.2055041051204516, 0.1089634021571866, -0.003090968625828524, 0.005018586734219781, 0.0]
K: [436.2518603710264, 0.0, 272.4668548867118, 0.0, 441.0091008894988, 174.4470981361869, 0.0, 0.0, 1.0]
R: [0.9980451574484078, 0.02122380979567181, 0.05878276610997515, -0.02121268522220995, 0.9997746548558092, -0.0008133225748451598, -0.05878678150270122, -0.0004352076567140128, 0.9982704668149054]
P: [445.2952930001379, 0.0, 240.8624572753906, 0.0, 0.0, 445.2952930001379, 179.0239391326904, 0.0, 0.0, 0.0, 1.0, 0.0]
binning_x: 0
binning_y: 0
roi:
  x_offset: 0
  y_offset: 0
  height: 0
  width: 0
  do_rectify: False
Im able to get the octomap but is not so good. Any help how to improve the map?
This is my Rviz. Fixed frame is base_link. Im not sure what should be the reference frame, as I dont have robot just hand hold the camera.
Here the map in rviz
Rviz with octomap
Now the problem is the null timestamp Left Camera
seq: 1280
  stamp:
    secs: 0
    nsecs:         0
height: 384
width: 512
D: [-0.2086468681317675, 0.1309844488937598, 0.001823015908195491, 0.003865352272151913, 0.0]
K: [451.5433695164733, 0.0, 262.2015316836384, 0.0, 454.8382333187173, 182.9314120544186, 0.0, 0.0, 1.0]
R: [0.9989286928378713, 0.01431409869945952, 0.04400651319570897, -0.0143430318904704, 0.99989707501352, 0.0003417829667208515, -0.04399709151081382, -0.0009726036343351752, 0.999031185689796]
P: [457.894691467317, 0.0, 240.6130847930908, 0.0, 0.0, 457.894691467317, 189.4381809234619, 0.0, 0.0, 0.0, 1.0, 0.0]
binning_x: 0
binning_y: 0
roi:
  x_offset: 0
  y_offset: 0
  height: 0
  width: 0
  do_rectify: False
Right Camera
header:
  seq: 2738
  stamp:
    secs: 0
    nsecs:         0
  frame_id: "/stereo_camera/right"
height: 384
width: 512
D: [-0.2228200499957892, 0.1973123886940819, 0.002679274149156493, 0.001686405084842895, 0.0]
K: [444.8007479437985, 0.0, 265.8307844199959, 0.0, 447.6530059966123, 193.6930325932133, 0.0, 0.0, 1.0]
R: [0.9988184466381711, 0.01405957605271069, 0.04651923232953362, -0.01402898365686818, 0.999901104726368, -0.000984065315183817, -0.04652846733846289, 0.0003302850394213167, 0.9989169097772479]
P: [457.894691467317, 0.0, 240.6130847930908, -58.04791693861652, 0.0, 457.894691467317, 189.4381809234619, 0.0, 0.0, 0.0, 1.0, 0.0]
binning_x: 0
binning_y: 0
roi:
  x_offset: 0
  y_offset: 0
  height: 0
  width: 0
  do_rectify: False
Thanks
Originally posted by Astronaut on ROS Answers with karma: 330 on 2018-08-21
From this warning:
[ WARN] (2018-08-21 15:29:10.585) Memory.cpp:749::update() The working memory is empty and the memory is not incremental (Mem/IncrementalMemory=False), no loop closure can be detected! Please set Mem/IncrementalMemory=true to increase the memory with new images or decrease the STM size (which is 1 including the new one added).
caused by this argument in the launch file:
  <arg name="localization"            default="true"/>
Set to false to do SLAM, otherwise there is no map constructed, thus no octomap. This should be only used when there is already a map constructed. When setting localization to true, it sets Mem/IncrementalMemory=False.
Also, don't include rtabmap.launch if you explicitly start stereo_odometry and rtabmap nodes, or use only rtabmap.launch (which starts stereo_odometry and rtabmap nodes, see original stereo_mapping.launch). You may have two stereo_odometry nodes and two rtabmap nodes started.
EDIT
I am not sure what you are expecting from the OctoMap and stereo, but the result you have seems okay. I took your launch file and tested on the dataset of this tutorial. I added the following at the top of your launch file to stream images from that dataset:
   <!-- stereo_20Hz directory -->
   <arg name="dir"        default="$(env HOME)/Downloads/stereo_20Hz" />
   <!-- Run stereo_sequence_publisher to publish synchronized images -->
   <node name="stereo_pub" pkg="bag_tools" type="stereo_sequence_publisher.py" output="screen">
      <param name="image_dir_left"         value="$(arg dir)/left"/>
      <param name="image_dir_right"        value="$(arg dir)/right"/>
      <param name="file_pattern"           value="*.jpg"/>
      <param name="camera_info_file_left"  value="$(arg dir)/stereo_20Hz_ros_left.yaml"/>
      <param name="camera_info_file_right" value="$(arg dir)/stereo_20Hz_ros_right.yaml"/>
      <param name="frequency"              value="20"/>
      <remap from="/stereo_camera/left/image_color"  to="/stereo_camera/left/image_raw" />
      <remap from="/stereo_camera/right/image_color" to="/stereo_camera/right/image_raw" />
      <remap from="/stereo_camera/left/camera_info"  to="/stereo_camera/left/camera_info" />
      <remap from="/stereo_camera/right/camera_info" to="/stereo_camera/right/camera_info" />
   </node>
   <node pkg="tf" type="static_transform_publisher" name="dummy_transform"
      args="0 0 0 0 0 0 stereo_camera/left stereo_20Hz_left 100" />
image description
Note that in this dataset, the ground is textured, so stereo can actually see the ground.
Originally posted by matlabbe with karma: 6409 on 2018-08-22
Comment by Astronaut on 2018-08-24:
I edit the question. change the launch file and edit that in the question. No more warnings, can get the octo map but the quality is not so good. Any help how to improve the map?
Comment by matlabbe on 2018-08-29:
Updated answer
Comment by Astronaut on 2018-09-02:
Ok. Thanks. Only one question. Why in your launch file the transform is stereo_camera/left stereo_20Hz_left? And when set up rviz what should be reference frame and what should be fixed in my case when have handhold camera? My transform is base_link stereo_camera/left 100. Thanks
Comment by matlabbe on 2018-09-03:
The global frame in RVIz is map. The frame stereo_20Hz_left is the one published by the stereo_sequence_publisher, I didn't want to modify your launch file, so I just added a new transform. You don't need it in your setup.
Comment by Astronaut on 2018-09-07:
I run again with same settings same launch file and now no map. I got this: Odometry.cpp:559::process() Null stamp detected [ INFO] [1536298042.556386146]: Odom: quality=924, std dev=0.026198m|0.000032rad, update time=0.000000s. Why no odometry now? same launch file
Comment by matlabbe on 2018-09-07:
What is the header of your image messages? Is the stamp always set?
Comment by Astronaut on 2018-09-09:
how to check that?
Comment by Astronaut on 2018-09-10:
rostopic hz /stereo_camera/left/image_rect the average rate: 5.145 min: 0.125s max: 15.334s std dev: 0.96139s window: 250
and the tf view_frames is diffrent. Map frame is gone.
its always same: Null stamp detected and update time=0.000000s. But Odom: quality=939, std dev=0.029415m. I dont understand where is the problem
I edit the camera info header. Please check
Comment by matlabbe on 2018-09-10:
Indeed the stamp in image topics is null. Modify the node publishing camera_info and the images to make sure the stamp is set to all topics. For example, the left camera info's stamp should be exactly the same than the left image topic's stamp.
I didn't change any nodes . You mean just to modify the node name in launch file?
Not sure what happened, but the node publishing the image seems not setting the stamp correctly. See why the node publishing the image is now publishing with null stamp.
Comment by Astronaut on 2018-09-11:
ok working now . But I can not see the disparity and rectified images now. What is the problem?
Comment by matlabbe on 2018-09-13:
Disparity and rectified images are published by stereo_image_proc, make sure the inputs are correct.
Comment by Astronaut on 2018-09-13:
Yes I know that are published by stereo_image_proc. What inputs do you mean?
Comment by matlabbe on 2018-09-14:
The inputs of stereo_image_proc, see example on its ros package description. If stereo_image_proc is not publishing anything, it is because it is not receiving anything or some of the input topics are not published...
