Our thesis is about Multicopter using two batteries wherein the first battery is used and when the power goes out, a switch is placed use to charge the first battery while the second battery is powering the multicopter, the process repeats again and again until all the power of the battery is drained. Is the process possible to achieved?
Edit 1: Just to clear everything up again. The thesis is about a Quadcopter that uses two batteries as its power source. These two batteries are attached to a "switching circuit system" that will allow one battery to be drained then the quadcopter will be transferred to the other battery. The solar panels serve as the "charger" of whatever battery is in its standby mode (the discharged battery). So while one battery is being used by the quadcopter, one will be connected to a solar panel which will be charging that battery. Once the other battery is drained, the quadcopter will switch to the charged battery. This will continue to go on until both batteries are drained. Is this achievable?
