Hello all,
I'm running ROS melodic on Ubuntu 18.04. I need help relative to the tf package
I have two frames in my /tf that I update with transformations for a few minutes. After a while, I want to look up one of the past transformations that I added. However, I don't want the need to declare the exact nsec but something close to it.
For example, let us say I have entrees at nsec= [912339188], [923085185] and [932359819]. Then, I want to run the following:
tf::TransformListener::waitForTransform( target_frame, source_frame, time, transform);
with time.nsec == 923085200
As you can see that is not the exact nsec as the ones in /tf but is very close to the second entree. Is there a way to get it? (I would prefer to avoid using tf2 if possible but will do it if needed)
p.s.
Currently, when ever I run tf::TransformListener::canTransform(...), with the above input information, it returns false.
Originally posted by Metalzero2 on ROS Answers with karma: 293 on 2018-08-13
So I found an other question on this forum that answers my question. It can be found here: https://answers.ros.org/question/10285/how-does-tf-do-interpolation/
I was not aware of the concept of "interpolation" of data points. It seems I do not need to have the exact time stamp in the tf for the transformation to be found, as long as my requested transformation is inside the buffer of the tf map.
Originally posted by Metalzero2 with karma: 293 on 2018-08-22
Comment by Metalzero2 on 2018-08-22:
p.s. although this question can be considered a duplicate, I would suggest not to delete it because there may be other people not familiar with the concept of interpolation.
