I'm using arduino to send values from 0.00 to 5.00 and I'm trying to read them but I get this error
raise ROSSerializationException(str(e)) rospy.exceptions.ROSSerializationException: <class 'struct.error'>: 'required argument is not a float' when writing 'x: "0.92"
this is the code, how can I convert the value to float?
def __init__(self):
rospy.init_node('my_tf_broadcaster')
self.ser = serial.Serial('/dev/ttyACM0', 115200)
    self.get_odometry()
def get_odometry(self):
self.pub_tf = rospy.Publisher("/tf", tf.msg.tfMessage)
    change = 0.0
            # Run this loop at about 10Hz
            rospy.sleep(0.1)
    message = self.ser.readline()
    t = geometry_msgs.msg.TransformStamped()
    t.header.stamp = rospy.Time.now()
        t.header.frame_id = "odom"
        t.child_frame_id = "base_link"
        t.transform.translation.x = message.rstrip()    #trying to read this value
        t.transform.translation.y = 1.0
        t.transform.translation.z = 0.0
        t.transform.rotation.x = 0.0
        t.transform.rotation.y = 0.0
        t.transform.rotation.z = 0.0
        t.transform.rotation.w = 1.0
    tfm = tf.msg.tfMessage([t])
        self.pub_tf.publish(tfm)
Originally posted by basicrobots on ROS Answers with karma: 1 on 2018-08-11
This is not a ROS question, but a Python one and you should have asked this on a more suitable forum (ie: one dedicated to Python development). Could you please review the support guidelines next time before you post?
In any case: the Python float(..) function accepts strings and will try to parse them for you, so passing whatever message.rstrip() returns to float(..) should work.
Edit:
if you really write x: "0.92" on the serial prompt (or whatever program you're using for that), then that will not work, as float(..) will not be able to parse that.
And whatever self.ser.readline() returns is not a simple float, but the actual string x: "0.92".
As that is not a float, the ROS msg serialiser cannot deal with that and returns you the error.
Again: not a problem with ROS, but with the way you're setting the values for the message fields.
Originally posted by gvdhoorn with karma: 86574 on 2018-08-12
Comment by gvdhoorn on 2018-08-12:
Note: indenting for your code is incorrect here, leading to only rospy.sleep(0.1) being executed as part of the while loop.
Comment by basicrobots on 2018-08-12:
correct in python I can just do float(..) and it would work, but ROS when it grabs the values puts "" quotation marks and that's what's throwing.
float(..) will parse strings, so I'm not sure what you are saying.
For me, something like: float('1.0') returns a valid float value.
