Is there a prerelease website for ROS2 similar to the ROS1 prerelease website? Are you planning to run one in case?
Originally posted by thinwybk on ROS Answers with karma: 468 on 2018-08-10
There is not currently an equivalent. I expect in the future that we will be able to extend that site to support both ROS 1 and ROS 2 distros in the future. We do not yet have the job types fully integrated for deploying it on ROS 2 versions of the distro yet.
Any interest or contributions would be appreciated and could likely make this happen sooner.
Originally posted by tfoote with karma: 58457 on 2018-08-10
Comment by Dirk Thomas on 2018-08-10:
We do have the logic for prerelease jobs for ROS 2. They are basically devel jobs run locally. Only the prerelease site doesn't support ROS 2 atm. Since the website only generates a command you need to run locally you can "construct" that manually.
You will need a custom ROSDISTRO_INDEX_URL mentioned in https://github.com/ros2/ros2/wiki/Releasing-a-ROS-2-package-with-bloom#differences-from-ros-1-bloom as well as the ros_buildfarm package from this branch: https://github.com/ros-infrastructure/ros_buildfarm/pull/548
