I have a rosperf package written in cpp, and runs alright using rosrun rosperf talker. Now I want to create rosperf command line tool (borrowed code from rosbag), but roslib.packages.find_node in rosperf_main.py cannot find the rosperf talker executable
How can I fix this? How to find the perf executable in python module?
This is the CMakeLists.txt
project(rosperf)
if(NOT WIN32)
  set_directory_properties(PROPERTIES COMPILE_OPTIONS "-g;-std=c++11;-Wall;-Wextra")
endif()
find_package(Boost REQUIRED COMPONENTS date_time thread)
find_package(catkin REQUIRED COMPONENTS message_generation rostime roscpp rosconsole roscpp_serialization std_msgs)
include_directories(${catkin_INCLUDE_DIRS} include)
link_directories(${catkin_LIBRARY_DIRS})
catkin_python_setup()
add_message_files(DIRECTORY msg FILES perf.msg)
generate_messages(DEPENDENCIES std_msgs)
catkin_package(
    LIBRARIES rosperf
    INCLUDE_DIRS include
    CATKIN_DEPENDS message_runtime std_msgs
macro(rosperf T)
  add_executable(${T} src/${T}/${T}.cpp)
  target_link_libraries(${T} ${catkin_LIBRARIES} ${Boost_LIBRARIES})
  add_dependencies(${T} rosperf_gencpp)
  install(TARGETS ${T}
    RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION})
endmacro()
foreach(dir
    perf_talker
    perf_listener
  rosperf(${dir})
endforeach()
Originally posted by foodtooth on ROS Answers with karma: 16 on 2018-08-09
Sorry, this is typo in roslib.packages.find_node causing the error. I will add other info if the problem re-occurs.
Originally posted by foodtooth with karma: 16 on 2018-08-09
