Is there a Matlab toolbox available to use Sick lasers in Windows?
I found one toolbox for Matlab in GNU/Linux. Is there another way to use Sick laser via Matlab in Windows?
  • $\begingroup$ If all fails, you can write your own using mex mathworks.com/help/matlab/… basically, get the example code from sick, see how they init the device and grab data from it. Write the stuff in mex to output the data in Matlab friendly format $\endgroup$ Feb 22 '13 at 18:04
  • $\begingroup$ SICK laser scanners send their data over a pretty simple serial interface. I'm sure you can find the API easily. Then it is just a matter of getting serial data in Matlab, which is a question for a different site. $\endgroup$
    – Ben
    Feb 15 '15 at 1:24
I have worked with the Sick LIDAR Matlab/C++ Toolbox, its pretty easy to use and does the job very well.
8
  • $\begingroup$ it is only for linux,finally i found same tool box ported to windows by one of the faculty.thanks for response. $\endgroup$
    – nayab
    Jun 12 '13 at 9:55
  • $\begingroup$ Your welcome, happy you solved your problem, you seem like you'll be doing some awesome stuff with your SICK :D $\endgroup$ Jun 12 '13 at 14:12
  • $\begingroup$ from your comment it seems that you got a ported version of the Sick LIDAR Matlab/C++ Toolbox. I tried porting the toolbox myself with no success. Would it be possible to get the Windows Version from you? $\endgroup$
    – user10008
    Jun 25 '15 at 10:25
  • $\begingroup$ Any chance you could post your own answer with a link to the windows version you found please @bvbdort , thanks. $\endgroup$
    – Mark Booth
    Jun 25 '15 at 14:59
  • $\begingroup$ Sorry, it was not online. It was from deportment. $\endgroup$
    – nayab
    Jun 29 '15 at 10:45
