I asked this question on the ros discourses, but wanted to put it here as well.
https://discourse.ros.org/t/explicitly-constraining-which-network-interfaces-are-used/5652/2
In raw dds, specifically for coredx, there is a way to give an interfaces list to the domain participant so that it will only talk on those network interfaces. Is there a way to use that through ros2?
Originally posted by nathan.jackson on ROS Answers with karma: 33 on 2018-08-07
The ROS 2 API doesn't contain a way to constrain the network interfaces at the moment. You might want to check the specific RMW implementation you want to use and use the vendor-specific configuration to do that (if available).
Originally posted by Dirk Thomas with karma: 16276 on 2018-08-07
Comment by nathan.jackson on 2018-08-07:
Thanks. Is there a specific way you would recommend for the rmw implementation to expose this type of thing?
Comment by William on 2018-08-07:
In all cases, you'd probably have to use XML files to configure the underlying implementation or else modify our code.
For FastRTPS (our default implementation right now), you might be able to start here: https://eprosima-fast-rtps.readthedocs.io/en/latest/pubsub.html#advanced-configuration
For Connext, see: https://community.rti.com/kb/how-do-i-restrict-rti-connext-use-only-subset-interfaces
Comment by vmanchal on 2020-03-23:
Has there been a support to this in the recent versions of ROS2? Something like Whitelist interfaces by eProsima? https://eprosima-fast-rtps.readthedocs.io/en/latest/advanced.html#whitelist-interfaces
Comment by EduardoPonz on 2021-04-06:
This is already supported in ROS 2 using Fast DDS interface whitelisting https://fast-dds.docs.eprosima.com/en/latest/fastdds/transport/whitelist.html. You can also check here how to configure ROS 2 with Fast DDS XML files https://fast-dds.docs.eprosima.com/en/latest/fastdds/ros2/ros2.html
