I am using arduino mega to run 4 motors via 4 motor controllers. I am using a ps2 controller as the remote control. When the joystick is at rest, the motor should stop.
The problem is the motor still moves randomly when the joystick is at rest. Sometimes, the joystick can only produce forward motion on the motor but not backward. Is this the grounding issue or the PS2 remote control issue ir others.. Does the GND from the arduino board have to be connected to the GND from the external battery?
How can I troubleshoot this?
Thanks.
