I have a project which possesses and uses G2O library, it runs on both platforms(win/Unix).
(WINDOW PASSED / UNIX CRASHED)
We can see in both platforms, these lines:
g2o::SparseOptimizer optimizer;
g2o::BlockSolver_6_3::LinearSolverType * linearSolver;
linearSolver = new g2o::LinearSolverDense<g2o::BlockSolver_6_3::PoseMatrixType>();
Next steps, in window os we have this:
g2o::BlockSolver_6_3 * solver_ptr = new g2o::BlockSolver_6_3(linearSolver);
g2o::OptimizationAlgorithmLevenberg* solver = new g2o::OptimizationAlgorithmLevenberg(solver_ptr);
But Unix system can't compile those lines because it says
my_file_G2o.cpp: In member function 'int Refiner_G2O::refinePose(cv::Mat&, const std::vector<cv::Point3_ >&, const std::vector<cv::KeyPoint>&, const cv::Mat&, float, std::vector&)': my_file_G2o.cpp --> no matching function for call to 'g2o::BlockSolver<g2o::BlockSolverTraits<6, 3>::BlockSolver(g2o::BlockSolver<g2o::BlockSolverTraits<6, 3>::LinearSolverType&)' ^ In file included from G2o/include/g2o/core/block_solver.h:199:0, G2o/include/g2o/core/block_solver.hpp:40:1: note: candidate: g2o::BlockSolver::BlockSolver(std::unique_ptr) [with Traits = g2o::BlockSolverTraits<6, 3>; typename Traits::LinearSolverType = g2o::LinearSolver<Eigen::Matrix<double, 6, 6, 0> >] BlockSolver::BlockSolver(std::unique_ptr linearSolver)
When I see these errors, I complete my Unix code with this new block
auto solver_ptr = g2o::make_unique<g2o::BlockSolver_6_3>(linearSolver); // [SEGFAULT LINE]
auto solver = g2o::make_unique<g2o::OptimizationAlgorithmLevenberg>(solver_ptr);
optimizer.setAlgorithm(solver.get());
So now, I can build/run but I meet a segfault on the line with [SEGFAULT LINE] tag.
I don't understand, why? if someone has an idea I want to understand how in Window it works and not in Unix system, will feel wonderful if you help.
LINUX Version: Ubuntu 16.04
CMAKE Version: 3.11.4
Best regards,
Originally posted by Simontraww on ROS Answers with karma: 16 on 2018-08-02
SOLVED:
G2O optimise:
auto linearSolver = std::make_unique<g2o::LinearSolverDense<g2o::BlockSolver_6_3::PoseMatrixType>>();
auto solver = new g2o::OptimizationAlgorithmLevenberg(std::make_unique<g2o::BlockSolver_6_3>(std::move(linearSolver)));
optimizer.setAlgorithm(solver);
MISC.H:
template<typename T, typename ...ArgTs>
std::unique_ptr<T> make_unique(ArgTs&& ...args)
  return std::unique_ptr<T>(new T(std::forward<ArgTs>(args)...));
Originally posted by Simontraww with karma: 16 on 2018-08-03
Comment by Vignesh_93 on 2020-12-12:
Can you explain the MISC.H, do we need to create this file separately or we can add this to the existing file itself ?
