I have two nodes, one publishes a topic (https://github.com/pitosalas/easy_filter/blob/master/scripts/obstacle_detector.py) that the other one (https://github.com/pitosalas/easy_filter/blob/master/scripts/livelyobstacles.py) subscribes to. What happens is if I run the publsher by itself, all is well. But if I do a rostopic echo on the relevant topic then the publisher starts throwing that exception.
Three notes:
  1. I've been debugging for a while, with control-c and kill commands to try and cleanup. I could be in some kind of bad state. But then my question is: how do I tell and how do I get out of the bad state? What do I reboot, my development computer, my robot, my roscore computer, all of them? And how do I avoid getting into this state.
  2. Minor: is the / before the topic name (when used in the publish or subscribe call) required, optional or sometimes yes and sometimes no?
  3. I am working in python,
Originally posted by pitosalas on ROS Answers with karma: 628 on 2018-08-01
Comment by NEngelhard on 2018-08-01:
It's much more likely that someone can help you debug your code if you show the code.
Comment by pitosalas on 2018-08-01:
Done. See links added above.
Sorry, I found the bug. See line 11 and 12 of the obstacle_detector.py:
    self.sub = rospy.Subscriber('/scan', LaserScan, self.scan, queue_size=1)
    self.pub = rospy.Publisher('obstacle', Obstacle, self.scan, queue_size =10)
As they say... "never mind" :(
Originally posted by pitosalas with karma: 628 on 2018-08-01
Comment by sirrarthur on 2021-06-29:
I made the same mistake putting the wrong arguments into the publisher. In my case I just wrote "10" instead of "queue_size = 10"
