Hello Here is what I'm trying to : I'm using an rplidar, arduino connected to Raspberry with ROS kinetic, to do autonomous mapping and navigation.
First, i run the rplidar with
roslaunch rplidar_ros view_rplidar.launch
then , slam mapping with
roslaunch rplidar_ros view_slam.launch
then I used hector_exploration with
roslaunch hector_exploration_node exploration_planner.launch
Final, to publish the cmd_vel topic I run
rosrun hector_exploration_controller simple_exploration_controller
My question, when I try to send cmd_vel values to Arduino through this code below
#include <ArduinoHardware.h>
#include <ros.h>
#include <geometry_msgs/Twist.h>
ros::NodeHandle nh;
geometry_msgs::Twist msg;
ros::Publisher pub("cmd_vel", &msg);
void setup()
 nh.initNode();
 nh.advertise(pub);
} void loop()
pub.publish(&msg);
nh.spinOnce();
Once I run this code on arduino, my rplidar stop spinning and give me this error message
[ WARN] [1532545086.000125786]: Shutdown request received.
[ WARN] [1532545086.000656149]: Reason given for shutdown: [new node registered with same name]
Originally posted by [email protected] on ROS Answers with karma: 35 on 2018-07-25
Node names need to be unique. You have more than one node with the same name. Make sure that every node name is unique and you won't get this behavior.
Originally posted by jayess with karma: 6155 on 2018-07-25
Comment by [email protected] on 2018-07-25:
Make sense, in this case the only node should be cmd_vel since everything working fine before running the arduino code ? If so, how can I change the node name and send to arduino in the same time ??
Comment by jayess on 2018-07-25:
It depends on which nodes are giving you trouble. The full error should say what the name of the node is.
Comment by jayess on 2018-07-26:
@[email protected] if this answered your question, please click on the check mark to mark this answer as correct.
