Good day everyone, now I'm working on a quadcopter project and I'm using IMU(gy-801) and also an ultrasonic sensor for getting the z-axis ,I have used the accelerometer and the gyroscope data to make the imu_msg and i've visualized this msg using rviz and it works very well then i have put the ultrasonic data and the heading angle in an odometry_msg,then i used this two messages in ekf_localization_node to get the pose and twist but the /odometry_filterd message that is published from that node doesn't give real data and the pose always increases fast although the quadcopter doesn't move. so am i working wrong or is there any configurations that i should consider?? thank you in advance
Originally posted by Mohamed Badra on ROS Answers with karma: 1 on 2018-07-25
Comment by Mohamed Badra on 2018-07-25:
so what sensor do you suggest for a quadcopter odometry?
Comment by stevejp on 2018-07-25:
I've seen a lot of people who use visual odometry. If you search google for "ros visual odometry" you'll find lots of examples.
thank you very much
If you're feeding noisy acceleration measurements into an EKF without a source of position odometry your position estimate is going to explode. You can do some searching for people who have tried using r_l with just an IMU, but from what I've seen the consensus is that the results won't be great.
Originally posted by stevejp with karma: 929 on 2018-07-25
