Hello I need a help regarding finding forward Kinametics and Inverse kinametics of a manipulator, I shall be thankful if any body can help me in this regard.
Originally posted by Sheby 99 on ROS Answers with karma: 1 on 2018-07-09
Hey
Basically, Kinematics explain the motion representation of the joint frame of the manipulator without considering the force and the torque that cause the joint’s motion. Thus, it depends on the robot that you want to find the kinematics, {how many degree-of-freedom / and what are the joints types (revolute/prismatic)}
You will not find a straight forward answer, you should first understand the idea and build your own kinematics.
I recommend you to check some kinematics videos in HERE you will understand the concept behind it, then you will be able to construct the kinematics solutions based on your robot.
I also recommend you to check this book,
Spong, Mark W., Seth Hutchinson, and Mathukumalli Vidyasagar. Robot modeling and control. Vol. 3. New York: Wiley, 2006.
Hope this helps,
Originally posted by Abdu with karma: 36 on 2018-07-09
Comment by Sheby 99 on 2018-07-09:
Thank you so much i know how to find forward and inverse kinametics but i need help it doing in ROS
See:
How can i find Kinametics of Youbot through this thanks for the reply
Comment by jarvisschultz on 2018-07-09:
If you have a URDF and are running the robot_state_publisher it should be easy to calculate the forward kinematics using tf. KDL can be used for forward/inverse using a URD... might want to check out pykdl_utils for an easy interface.
If you are using MoveIt!, trac_ik, bio_ik, and KDL can be used through standard MoveIt! interfaces. Since it sounds like you are just looking at the youBot, you might want to check out this youbot_manipulation package that...
contains an IK solution specifically for the youBot.
Thank u so much for the reply actually i want to solve this lab https://github.com/surgical-vision/compgx01_lab I have made the tf listener now i am looking for finding Forward Kinametics and Inverse Kinametics so i need a help in this regard Thanks in anticipation
Comment by jarvisschultz on 2018-07-10:
If you have a URDF+join_state information+robot_state_publisher you can just query for the transform from the base of your robot to the end-effector of your robot using your listener to get the result of the forward kinematics problem.
As you might be getting the sense, there are a lot of kinematics packages and tools out there capable of solving your FK and IK problems, but none of them work without a little bit of work/configuration on your part. We've pointed out quite a few solutions for you...
... my advice would be to investigate these solutions to and then ask new questions about specific packages as they arise. I think it is unlikely that someone will just solve your problem for you, and there is no one-size-fits-all answer to this question.
Comment by Sheby 99 on 2018-07-11:
Cheers for the help!! Much Appreciated
