Can I use bloom to build deb packages from ROS2 Bouncy Bolson packages like bloom is used to build deb packages from ROS1 packages ?
Originally posted by thinwybk on ROS Answers with karma: 468 on 2018-07-07
Yes, bloom is being used to release ROS 2 packages in (almost) the same way as for ROS 1. Please see these instructions about the differences in setup and which version is needed at least: https://github.com/ros2/ros2/wiki/Releasing-a-ROS-2-package-with-bloom
Originally posted by Dirk Thomas with karma: 16276 on 2018-07-07
