Hello everyone,
I wanna update tf to tf2 in my code, but get some question about it.
There are tf part :
tf::TransformListener listener;
tf::StampedTransform transform;
try
    listener.waitForTransform("/map", "/base_link", ros::Time::now(), ros::Duration(2));
    listener.lookupTransform("/map", "/base_link", ros::Time(0), transform);
catch(tf::TransformException ex)
    ROS_ERROR("%s", ex.what());
    ros::Duration(1.0).sleep();
    QMessageBox::information(this, "Error", QString::fromStdString(ex.what()));
    return ;
geometry_msgs::Transform tt;
tf::transformTFToMsg(transform, tt);
pose.position.x = tt.translation.x;
pose.position.y = tt.translation.y;
pose.position.z = tt.translation.z;
pose.orientation.x = tt.rotation.x;
pose.orientation.y = tt.rotation.y;
pose.orientation.z = tt.rotation.z;
pose.orientation.w = tt.rotation.w;
pose is a parameter, via geometry_msgs::Pose &pose
When I follow the doc to update to tf2, I get some wrong.
There are tf2 part:
tf2_ros::Buffer tfBuffer;
tf2_ros::TransformListener tfListener(tfBuffer);
geometry_msgs::TransformStamped transformStamped;
try
    transformStamped = tfBuffer.lookupTransform("/map", "/base_link", ros::Time(0));
catch (tf2::TransformException &ex){
    ROS_WARN("%s", ex.what());
tf::transformTFToMsg(transformStamped, tt);
I Don't know how to transfrom data under tf2, and I didn‘t find the relevant function in doc.
I want to know how to modify my code to achieve the same result?
Is there a function just like transformTFToMsg I can replace?
Originally posted by TifferPelode on ROS Answers with karma: 96 on 2018-06-26
In your first example, you make a tf::StampedTransform to hold the transform, then use transformTFToMsg to put it into a message object.
In the second example, tf2 is already returning a geometry_msgs::TransformStamped message type (instead of a StampedTransform object). So you're trying to convert a message to a message. You're effectively doing this:
But those are both message types, so you don't need to do that at all. You have two options:
  1. Use transformStamped instead of tt in the rest of your code, since they are both messages.
  2. Just do this:
    <your transform try/catch block>
    geometry_msgs::Transform tt = transformStamped.transform;
Originally posted by Tom Moore with karma: 13689 on 2018-06-26
Comment by TifferPelode on 2018-06-26:
Thank you for your detailed explanation, it really wake me up.
