Hello,
I'm trying to use rosserial with Teensy 3.5 through bluetooth.
My first step: change the serial port from Serial to Serial1.
I follow the thread: https://answers.ros.org/question/198247/how-to-change-the-serial-port-in-the-rosserial-lib-for-the-arduino-side/?answer=295159#post-id-295159
It compiles with Arduino Mega board but no with Teensy 3.5 (or other Teensy boards)
I use: Ubuntu 16.04, Kinetic ros, Arduino 1.8.5 The Hello World example code: http://wiki.ros.org/rosserial_arduino/Tutorials/Hello%20World
I tried to ways:
  1. Modify the line 73 in the code arduino.1.8.5/libraries/ros_lib/ArduinoHardware.h
iostream = &Serial1;
  1. Replace:
    ros::NodeHandle nh;
with:
class NewHardware : public ArduinoHardware
  public:
  NewHardware():ArduinoHardware(&Serial1, 57600){};
ros::NodeHandle_<NewHardware>  nh;
The error when I try to compile is:
.../arduino-1.8.5/libraries/ros_lib/ArduinoHardware.h:67:5: note:   no known conversion for argument 1 from 'HardwareSerial*' to 'usb_serial_class*'
no matching function for call to 'ArduinoHardware::ArduinoHardware(HardwareSerial*, int)'
ArduinoHardware.h: http://docs.ros.org/jade/api/rosserial_arduino/html/ArduinoHardware_8h_source.html
Originally posted by jordiguerrero on ROS Answers with karma: 16 on 2018-06-24
Comment by jayess on 2018-06-24:
What is your original problem (i.e., please update your question with a copy and paste of the error)? Why are you modifying the source code of a library? Can you please update your question with a copy and paste of of the code that you wrote?
Comment by gvdhoorn on 2018-06-25:
@jordiguerrero: please post your last edit as an answer, and then accept your own answer.
Also: I don't see #define USE_TEENSY_HW_SERIAL in your last edit?
Comment by jordiguerrero on 2018-06-25:
Ok, I make the changes. Sorry about any inconvenient, it is my first post...
No need to apologise. Just keep it in mind for next time.
SOLVED: I forget to add the next include:
#define USE_USBCON
It was solved in the teensy forum, thank you to Theremingenieur user: https://forum.pjrc.com/threads/52928-rosserial-bluetooth-teensy-problem
The modified Hello World sample:
 * rosserial Publisher Example
 * Prints "hello world!"
// Use the following line if you have a Leonardo or MKR1000
#define USE_USBCON
#include <ros.h>
#include <std_msgs/String.h>
//ros::NodeHandle nh;
  public:
std_msgs::String str_msg;
ros::Publisher chatter("chatter", &str_msg);
char hello[13] = "hello world!";
void setup()
  nh.initNode();
  nh.advertise(chatter);
void loop()
  str_msg.data = hello;
  chatter.publish( &str_msg );
  nh.spinOnce();
  delay(1000);
Originally posted by jordiguerrero with karma: 16 on 2018-06-25
