I'm hoping to use a DC motor to drive a cog bar horizontally along a track. AFAIK, I'd need to install a (plastic) cog on the motor shaft, which itself grips on the (plastic) cog bar. Does anyone know how to prevent the cog from shifting on the shaft? The shaft is 10mm long and I'd like to make sure the cog cog sits at 5mm, where the cog bar is.
Any help will be appreciated.
Thanks
