I am working on proposal of autonomous fire fight robots but I'm little bit confused about its sensor and algorithms. My friend suggested there are some path finding AI algorithms like BFS, DFS, A*, and Dijkstra's Algorithm which are used in robots, but I didn't believe it.
I want to ask: Are these algorithms used in real world robots or some other genetic algorithms? How does a robot discover path to detect, and differentiate, a human from fire? I only want some explanation that gives knowledge.
  • 4
    $\begingroup$ This question is unclear. It can be improved by giving a specific problem definition that can be answered clearly and without ambiguity or opinions. $\endgroup$ Dec 22, 2015 at 16:06
  • $\begingroup$ @JoshVanderHook what you want to say does this question is broad $\endgroup$
    – Ven Nilson
    Dec 23, 2015 at 9:23
in my opinion one possibility on how the robot could find people with fire is by using image processing. You can obtain a real time Infra red image of the outside world and then check for levels of heat measured. Using recognition alogirthms the robot could decide whether a particular figure is a human or not and if it is a human then by checking the heat generated it could decide whether the person is in danger or not. The source of heat could be the main setpoint that the robot wants to reach.
  • $\begingroup$ Comments are not for extended discussion; this conversation has been moved to chat. $\endgroup$
    – Mark Booth
    Jan 4, 2016 at 10:25
