Hi,
I'm having problems in finding reliable IMU's in ROS. So far, I have tried the UM7 and the myAHRS+ with no luck. The first one, keeps resetting its magnetic reference and the second one works well but the x axis is pointing to the north ( x-north, y-west, z-up convention ) instead to the east ( ROS convention x-east, y-north, z-up convention ).
Does anybody know one that works out of the box?
Best,
Originally posted by andrestoga on ROS Answers with karma: 188 on 2018-05-22
Comment by BrettHemes on 2018-05-22:\
This is just convention and can be fixed simply by rotating the outputs to correspond with the ROS expectations
Check out razor IMUs: http://wiki.ros.org/razor_imu_9dof
I've worked with them and with the ROS package the setup is easy and it works flawlessly with this one: https://www.sparkfun.com/products/retired/10736
But as you see that has been retired, when I bought it I got the https://www.sparkfun.com/products/14001 and there are some PRs on the page of the razor_imu_9dof to make it work with the M0.
Note the video from razor_imu_9dof: https://youtu.be/5FALgpOlgvw
Originally posted by bpinaya with karma: 700 on 2018-05-22
Comment by andrestoga on 2018-05-22:
Great! Thanks!
When you refer to the page of the razor_imu_9dof, are you talking about this webpage: http://wiki.ros.org/razor_imu_9dof?
What does PR stand for?
Best,
Comment by bpinaya on 2018-05-23:
PR = Pull Request, sorry. And when I said the page I refer to the github repo, from what I've seen so far there is a fork with the code for the M0 so you are good to go: https://github.com/KristofRobot/razor_imu_9dof
Comment by andrestoga on 2018-07-03:
@bpinaya did you ever run into this problem? https://github.com/KristofRobot/razor_imu_9dof/issues/41
Comment by bpinaya on 2018-07-04:
Not really, but from what I see it's due to the config file: https://github.com/KristofRobot/razor_imu_9dof/search?q=cfg&unscoped_q=cfg Maybe an old branch? I'll give it a look in the weekend, but when I used it it was straight forward.
Comment by andrestoga on 2018-07-04:
I forgot to catkin_make to generate the files for the dynamic reconfigure and now it works.
Comment by bpinaya on 2018-07-05:
hehehe no problem, it's always better to remove /devel and /build and catkin_make again. If you liked my answer please accept it ;)
Comment by aarontan on 2018-07-08:
@andrestoga I am having troubles with the razor IMU, I am using https://www.sparkfun.com/products/retired/10736 with an arduino mega. Can you provide some details about your setup? thank you
Comment by andrestoga on 2018-07-09:
@aarontan please ask it in another thread and share the link of your question in the comments so, I can help you out. Also, you can post your issue here https://github.com/KristofRobot/razor_imu_9dof/issues
