I am having difficulty following the wiki
http://wiki.ros.org/lunar/Installation/Ubuntu
$ sudo apt-get update
Get:1 file:/var/cuda-repo-9-0-local-cublas-performance-update-2  InRelease
Ign:1 file:/var/cuda-repo-9-0-local-cublas-performance-update-2  InRelease
Get:2 file:/var/cuda-repo-9-0-local-cublas-performance-update  InRelease
Ign:2 file:/var/cuda-repo-9-0-local-cublas-performance-update  InRelease
Get:3 file:/var/cuda-repo-9-0-local  InRelease
Ign:3 file:/var/cuda-repo-9-0-local  InRelease
Get:4 file:/var/cuda-repo-9-1-local-cublas-performance-update-1  InRelease
Ign:4 file:/var/cuda-repo-9-1-local-cublas-performance-update-1  InRelease
Get:5 file:/var/cuda-repo-9-1-local  InRelease
Ign:5 file:/var/cuda-repo-9-1-local  InRelease
Get:6 file:/var/cuda-repo-9-0-local-cublas-performance-update-2  Release [574 B]
Get:7 file:/var/cuda-repo-9-0-local-cublas-performance-update  Release [574 B]
Get:8 file:/var/cuda-repo-9-0-local  Release [574 B]
Get:9 file:/var/cuda-repo-9-1-local-cublas-performance-update-1  Release [574 B]
Get:10 file:/var/cuda-repo-9-1-local  Release [574 B]
Ign:12 http://packages.linuxmint.com sylvia InRelease
Hit:13 http://storage.googleapis.com/bazel-apt stable InRelease
Hit:14 http://packages.linuxmint.com sylvia Release
Ign:15 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:17 http://packages.ros.org/ros/ubuntu sylvia InRelease
Ign:18 http://packages.ros.org/ros/ubuntu sylvia Release
Hit:20 http://dl.google.com/linux/chrome/deb stable Release
Ign:21 http://packages.ros.org/ros/ubuntu sylvia/main amd64 Packages
Hit:22 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu xenial InRelease
Hit:23 http://archive.canonical.com/ubuntu xenial InRelease
Hit:24 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:25 http://security.ubuntu.com/ubuntu xenial-security InRelease
Ign:26 http://packages.ros.org/ros/ubuntu sylvia/main i386 Packages
Ign:28 http://packages.ros.org/ros/ubuntu sylvia/main all Packages
Ign:29 http://packages.ros.org/ros/ubuntu sylvia/main Translation-en_US
Hit:30 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Ign:31 http://packages.ros.org/ros/ubuntu sylvia/main Translation-en
Hit:33 http://ppa.launchpad.net/webupd8team/java/ubuntu xenial InRelease
Hit:34 http://archive.ubuntu.com/ubuntu xenial-backports InRelease
Err:21 http://packages.ros.org/ros/ubuntu sylvia/main amd64 Packages
  404  Not Found [IP: 64.50.233.100 80]
Reading package lists... Done
W: The repository 'http://packages.ros.org/ros/ubuntu sylvia Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://packages.ros.org/ros/ubuntu/dists/sylvia/main/binary-amd64/Packages  404  Not Found [IP: 64.50.233.100 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
It is ignoring my changes to the repository.
I was not able to accomplish the first step: "Configure your Ubuntu repositories". Linux Mint is essentially Ubuntu but the interface is different. Does anyone know how to do that?
Thank you.
Originally posted by gm9089zo on ROS Answers with karma: 3 on 2018-05-19
Which makes sense, as sylvia is not an Ubuntu release code name, and the ROS buildfarm does not build packages for it (or at least: it doesn't store any release file for it).
This error also tells you that.
Provided sylvia is compatible with one of Ubuntu's distributions (I haven't checked), you can try to see whether setting ROS_OS_OVERRIDE (docs) to a suitable value works. Be sure to also update your /etc/apt/sources.list.d/ros-latest.list to use the same value(s).
Finally: how to install ROS Ubuntu packages on Ubuntu derivatives has been asked a few times before. A search (with Google: site:answers.ros.org <your search terms>) should lead you to some usable information.
Edit: looks like sylvia is essentially Ubuntu Xenial. A value for ROS_OS_OVERRIDE could be: ubuntu:16.04.
Originally posted by gvdhoorn with karma: 86574 on 2018-05-20
Comment by gm9089zo on 2018-05-20:
Thank you!
Hello, this post talks about the same problem:
https://answers.ros.org/question/245325/troubles-installing-ros-kinetic-on-linux-mint-sarah-18/
There problems is, when you add the Ros repository, you need to change the name of the release to Ubuntu's release name, in this case Xenial. So, instead of use
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
You should change for
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu xenial main" > /etc/apt/sources.list.d/ros-latest.list'
Because, otherwise, the repository uses the Mint distribution name, and there isn't.
Originally posted by Pedro Alcantara with karma: 56 on 2018-05-20
Yes, this is also correct. Thank you. I should've been able to crack it myself. :-)
Comment by Diogo42 on 2019-09-14:
Thank`s this works for me
