Hey there,
I would like to subscribe a field of a message array.
E.g. if my message looks like this:
BallStates.msg:
BallState[] ball_states
BallState.msg:
std_msgs/Header header
uint32 uid
geometry_msgs/Point position
Only the BallStates.msg is published. And I would like to subscribe to the first ball in this message with message_filters
self.topic2_sub = message_filters.Subscriber("/ball_states[0]/ball_state" , BallState)
ts = message_filters.TimeSynchronizer([self.topic1_sub, self.topic2_sub], 10)
ts.registerCallback(self.topic12_cb)
For that however I get this error:
ball_states[0]/ball_state' is not a legal ROS graph resource name. This may cause problems with other ROS tools
  super(Subscriber, self).__init__(name, data_class, Registration.SUB)
However if I echo that topic in a terminal by rostopic echo /ball_states[0]/ball_state it works :)
Does anyone know a fast workaround to this?
I mean of course I can kind of publish the first ball in an extra message and subscribe to that one but this is actually not what I want.....
I would like to have a fast short solution that does not cost time....
Note something like this:
  <remap from="ball_states[0]" to="ball1"/>
also will not work for me...:
Invalid <remap> tag: remap from [/turtlebot3/ball_tracking/ball_states[0]] is not a valid ROS name.
XML is <remap from="/turtlebot3/ball_tracking/ball_states[0]" to="ball1"/>
The traceback for the exception was written to the log file
Originally posted by Markus on ROS Answers with karma: 311 on 2018-05-16
this is not supported.
yes, but that is a 'trick': rostopic subscribes in the regular way and then filters its output for you, so it appears to subscribe to a field (which is impossible). See #q232748 fi.
No.
No, because remapping fields is also not supported.
Yes, wouldn't we all.
Perhaps it would be good if you can explain what it is that you are actually trying to do, instead of us trying to suggest alternatives for a solution you've already chosen.
Something that could perhaps work for you is to use the transform node from topic_tools to republish a single field as a separate message. See #q232748 again for how that could be done.
Originally posted by gvdhoorn with karma: 86574 on 2018-05-16
Comment by Markus on 2018-05-16:
Thanks :) well but wouldn't that be a nice feature... ? To be easily able to subscribe a message of a message array? I kind of miss that and simply wanted to know if something like this exists....
Comment by gvdhoorn on 2018-05-16:
There's all sorts of issues with subscribing to individual fields that make this less convenient than it appears. That's probably why this hasn't been added/implemented. See some earlier Q&As about this same topic.
See my edit for a possible approach. It would be almost like your remapping example.
