Hi, guys. I'm a newbie in the ROS world and i have to install it. Following this guideline: http://wiki.ros.org/kinetic/Installation/Ubuntu. when i reach the point 1.6 and i execute this:
echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc source ~/.bashrc
i get this "error": bash: source/opt/ros/kinetic/setup.bash: No such file or directory
Any advice to fix this problem? Thanks in advance
P.S. i'm also newbie on Linux, so i have to learn quickly a lot of stuff
Originally posted by lolito on ROS Answers with karma: 16 on 2018-05-15
Comment by gvdhoorn on 2018-05-15:
Did you run that all in one command? Because those are at least two separate commands: one starting with echo and the other with source.
Nope, i run them separately...anyway i redo the ubuntu installation and then the ROS installation all works fine. In any case thanks a lot for the feedback! :) only one more question: is there a link(website) where i can learn, maybe through a tutorial, the main features of turtlesim?
Originally posted by lolito with karma: 16 on 2018-05-15
re: turtlesim: that would probably be wiki/turtlesim/Tutorials.
