A few days ago I succeed mapping on my laptop
Now I trying to mapping as hector slam on raspberry pi3 (ubuntu mate)
By the way mapping not work on raspberry
I think the environment of raspberry is equal the environment of laptop
First my procedure is
  1. Downloading pakage about this project (Hector_Slam, ros_rplidar)
  2. building the files (catkin make) , setting a port
  3. modifying code of mapping_default.launch of hector_mapping file in hector slam.
I did not modify anything else
The result of implementation is like this
image description
I changed fixed map : map , laser , base_frame and and added map on dispaly list (topic : /map)
a error not generate on terminal but also map not appear
what is problem??
Originally posted by DongHyeong Kang on ROS Answers with karma: 13 on 2018-05-02
image description
I attach my tf tree screen shot
please see and tell me why mapping not work
This problem is error in building
after initialization raspberrypi , retry to building slam file
It is work
Originally posted by DongHyeong Kang with karma: 13 on 2018-05-03
Comment by billyDong on 2018-05-04:
For now I cab only be sure that /hecto_mapping is not publishing any topic with a map. But you hided the terminal with the information about the topics..
I think you should write parameters for the map size and resolution also..
Comment by billyDong on 2018-05-04:\
Comment by DongHyeong Kang on 2018-05-04:
Thank you so much billy So can I write them in mapping_default.launch? I’m sorry . Can I see the simple example??
Comment by billyDong on 2018-05-08:
https://pastebin.com/vdmjPJet There you have the file that I use
