I want to use information received from the different nodes in one callback function. I am not sure. For example my callback function
void follow(const geometry_msgs::PoseStamped::ConstPtr& fmsg, const geometry_msgs::PoseStamped::ConstPtr& gmsg ){ #and do something with than info}
Subscribers
ros::Subscriber pos_sub_uav1 = nh_uav1.subscribe<geometry_mgs::PoseStamped>
        ("uav1/mavros/local_position/pose", 10, follow);
ros::Subscriber pos_sub_uav2 = nh_uav2.subscribe<geometry_mgs::PoseStamped>
        ("uav2/mavros/local_position/pose", 10, follow);
One way I think of is to make separate callback functions for each subscriber node and then receive messages from corresponding nodes, store info in some global variable and the use other function for manipulation of those variables or there is a better way to do this.
Originally posted by Nebula on ROS Answers with karma: 98 on 2018-04-20
You could do something like this:
ros::Subscriber pos_sub_uav1 = nh.subscribe<geometry_mgs::PoseStamped>("uav1/mavros/local_position/pose", 10, boost::bind(&follow, _1, "uav1"));
ros::Subscriber pos_sub_uav2 = nh.subscribe<geometry_mgs::PoseStamped>("uav2/mavros/local_position/pose", 10, boost::bind(&follow, _1, "uav2"));
void follow(const geometry_msgs::PoseStamped::ConstPtr& msg, const std::string &uav) { }
You might also want to just use a time sychronizer.
Originally posted by Tom Moore with karma: 13689 on 2018-04-20
Comment by Nebula on 2018-04-21:
can I get messages in callback function from both(or many) subscribers simultaneously?
Comment by Tom Moore on 2018-04-21:
If you use the time synchronizer, yes.
