Hello. I'm new to ros.I set my scene in VREP and got my robot using kinect. I'm trying to create a map of the environment, but for this I need to convert the data from pointcloud to laserscan, but I have no idea how to do this.
Originally posted by Dieisson Martinelli on ROS Answers with karma: 11 on 2018-04-17
3 Answers 3
Please see:
  • #q224463
  • #q11232
  • #q238481
  • #q235009
  • #q10568
  • #q188444
  • #q73186
This has been asked many times before, but it can be a little difficult to find these answers using the search function on the site. You can try entering the following search terms in Google:
<question> site:answers.ros.org
where <question> is your question. This will perform a search of ROS Answers using your question as a term.
For example, your question would be:
https://www.google.com/search?q=convert+point+cloud+to+laserscan+site%3Aanswers.ros.org
Originally posted by jayess with karma: 6155 on 2018-04-17
Comment by paulbovbel on 2018-07-06:
Funnily enough, the links provided mostly talk about how to convert a laserscan into a pointcloud :)
Comment by jayess on 2018-07-06:
Good catch. This is what happens when you have too many tabs open at once.
There is a package to convert pointclouds to laserscans - http://wiki.ros.org/pointcloud_to_laserscan. The parameters are documented on the wiki, and some sample launch files are provided in the package source.
Originally posted by paulbovbel with karma: 4518 on 2018-07-06
This question tackles the same problem (but with velodyne pointcloud) using the pointcloud_to_laserscan package.
Here is another example of converting pointcloud to laserscan that you can checkout.
