Hi, I'm using ROS Kinetic and I'm currently trying to set up the navigation package. I've got a hexapod with a lidar on top and navigation is working fine for this configuration. But recently I added an ultrasonic sensor to the front to avoid bumping into glas doors and unfortunately I can't get the range_sensor_layer to run.
This is my costmap_common_params.yaml:
obstacle_range: 2.5
raytrace_range: 3.0
footprint: [[0.3, 0.3], [0.3, -0.3], [-0.3, -0.3], [-0.3, 0.3]]
#robot_radius: ir_of_robot
inflation_radius: 0.35
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: laser_frame, data_type: LaserScan, topic: scan, marking: true, clearing: true}
plugins:
- {name: sonar_layer, type: "range_sensor_layer::RangeSensorLayer"}
sonar_layer:
topics: ["/us/range"]
My local_costmap_params.yaml:
local_costmap:
global_frame: odom
robot_base_frame: base_footprint
update_frequency: 5.0
publish_frequency: 2.0
static_map: false
rolling_window: true
width: 6.0
height: 6.0
resolution: 0.05
And my global_costmap_params.yaml:
global_costmap:
global_frame: /map
static_map: true
When I try to launch navigation I get this error, which leads to the process move_base dying:
[ INFO] [1455210855.302734798]: Using plugin "sonar_layer" terminate called after throwing an instance of 'pluginlib::LibraryLoadException'
what(): According to the loaded plugin descriptions the class range_sensor_layer::RangeSensorLayer with base class type costmap_2d::Layer does not exist. Declared types are costmap_2d::InflationLayer costmap_2d::ObstacleLayer costmap_2d::StaticLayer costmap_2d::VoxelLayer rtabmap_ros::StaticLayer
I tried to put the plugins-tag into local_costmap_params.yaml already which lets navigation get launched but it will ignore the range-message for obstacle detection. The topic \us\range is not subscribed by any other node in this configuration.
Is there anything I did wrong with including the range_sensor_layer-plugin for navigation?
Originally posted by MarcoStb on ROS Answers with karma: 80 on 2018-04-09
