Hi everyone!
I was wondering if there is any way you can open rviz from a launch file while openning a custom configuration. The terminal command would be:
rosrun rviz rviz -d `rospack find package_name`/rviz/config_file.rviz
Thank you!
Originally posted by alextac98 on ROS Answers with karma: 113 on 2018-04-05
Post score: 5
Yes:
<launch>
  <node type="rviz" name="rviz" pkg="rviz" args="-d $(find package_name)/rviz/config_file.rviz" />
</launch>
Note that this is the same approach you would use for any program / node that accepts command line arguments. Doing it in a launch file just allows you to use the find substitutation command.
Originally posted by gvdhoorn with karma: 86574 on 2018-04-05
Post score: 24
