MEMS gyros all have a problem with drift due to temperature. This can be worked around using several techniques, and higher cost parts generally have some amount of compensation built in. However, in my experience even the most expensive gyros need some individual calibration or sensor fusion techniques to deal with drift.
Taking a look at this sensor package, the 3 axis gyro is not calibrated for temperature, but does include a temperature sensor. This is pretty common in low cost gyros.
As an aside, I would not consider this part an IMU since it does no sensor fusion or calibration between the gyro, temperature sensor, accelerometer and magnetometer. This is reflected in its price.
Anyway, what that means is you will need to come up with a way to deal with the gyro drift yourself.
The best technique is going to depend on your application and budget, but here are some approaches to look at:
- Buy a better IMU: Depending on your budget, this may be the simplest solution. Expect to spend between $50-$100.00 for such a device.
- Have an operational calibration process: In this case, you would measure the drift rate of each axis every time you knew it was not in motion, keeping it updated in a moving average and apply that as an offset to the measured rate. This is a simple solution if you have a way of knowing that the sensor is not moving and that will happen regularly during operation.
- Calibrate the offset for temperature: If you have access to a precision thermal chamber, you can pre-calculate the drift rate vs temperature function and update it on the fly. This works best if combined with an occasional stopped calibration.
- Implement a Complementary or Kalman filter to process the data. This is described in the answers to https://stackoverflow.com/questions/1586658/combine-gyroscope-and-accelerometer-data and can be combined with 2 and 3.
