Hi,
I am trying to fuse data from an IMU and a visual odometry node with robot_localization in order to have a better localization for my robot.
The IMU is a Tinkerforge IMU Brick 2.0; the visual odometry node is the one provided in the package rtabmap_ros.
Both nodes work well, and the extended kalman filter does what it's supposed to do.
I am using ROS kinetic on Ubuntu 16.04.
The only issue that I'm facing is when the visual odometry gets lost: in this case the node publishes a message like that:
header:
seq: 769
stamp:
secs: 1522407457
nsecs: 640873928
frame_id: "odom"
child_frame_id: "kinect2_base_link"
pose:
pose:
position:
x: 0.0
y: 0.0
z: 0.0
orientation:
x: 0.0
y: 0.0
z: 0.0
w: 0.0
covariance: [9999.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 9999.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 9999.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 9999.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 9999.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 9999.0]
twist:
twist:
linear:
x: 0.0
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.0
In this case the kalman filter still continues to work, and this results in the estimante odometry having an erroneous translational velocity.
How can I face with this?
I was thinking about a way to "pause" the kalman filter until the visual odometry returns working but actually I can't figure it out.
Thank you in advance for all your support!
Originally posted by nicopal on ROS Answers with karma: 11 on 2018-03-30
Comment by Dronist on 2020-07-29:
I've tried to fuse the data from the visual odometry with the IMU(all from the realsense D435i)
And I'm getting this drift as shown in the video:
https://drive.google.com/file/d/1-_k5nmxgYUYPFH6EEnVOruqDtIrEcOlu/view?usp=sharing
The second the visual odometry gets lost the odometry starts drift
Even when Im setting publish_null_when_lost to false
Any suggestions?
