I worked with ROS for a couple of weeks and now need to upgrade to ROS2 due to its DDS feature. Although i know that ROS2 offers a bridge for ROS1 but just to be sure i want to ask if i can install ROS2 on the same machine as ROS or shall i create another VM to install ROS2 seperately ?
Originally posted by aks on ROS Answers with karma: 667 on 2018-03-29
Yes.
If you're using Ubuntu Xenial as your OS you could even use the provided binaries (Installing ROS2 via Debian Packages).
Originally posted by gvdhoorn with karma: 86574 on 2018-03-29
Comment by aks on 2018-03-29:
And what if i want to do it the other way round ? i.e. I installed ROS2 first (from source) and then I want to use to features of ROS using the ROS bridge. Is it then possible ? As now i dont have any ROS installed.
Comment by gvdhoorn on 2018-03-29:
Provided you are using an OS that is supported by ROS1 it should be possible.
